Transmission fluid change question
i am going to be changing out my transmission fluid in my '04 TL today and have a question. i know the popular method is the 3+3, but when you pull the drain plug, do you have to monitor how much drains out of the transmission, or does only about 3 quarts drain out?
by doing the 3+3 method, aren't we simply mixing old fluid with new, and essentially leaving a mix of old and new fluid in the tranny since the new fluid does not magically keep itself separated from the old fluid by doing the 3+3 method??
thanks in advance!
thanks in advance!
I just changed my ATF last weekend for the first time at 22.5K. I have a different take on the 3x3 idea and will just change the ATF sooner and skip doing the 3x3.
If you look at the magnetic drain bolt you'll that there is lots of metallic material on this bolt- at least the first time anyway. By changing around 20K, I'm essentially doing a 3x3 at 60K anyway and not wasting as much fluids. I have issues dumping ATF that is only 15 minutes old doing the 3x3.
takin care of Business in
the best way to get all the old fluid out is 3x3....i did my tranny flush and this is what i did....
1>drive the car onto the ramp
2>take the drain bolt out and let the fluid run
3>loosen the fill bolt
4>clean drain bolt with some new fluid
5>when the fluid stops running replace bolt
6>open the bolt in the hood to fill new atf
7>clean the bolt with some new fluid
8>put in the 3 quarts
9>drive car off the ramp and take it for a little spin
10>drive in all gears for about 2-3 mins
11>repeat steps 1-10....2 more times
so by the time you are done you will use up 9 quarts.....i then did a drain and refill (only once, using 3 quarts) in the next 5000 miles.....
thanks in advance!
thanks in advance!
^^^ its not recommended to Suck out the old fluid and put new fluid in because you just sucked out the old fluid but not the metal shavings inside the tranny.....
drain and refill at every oil chance or 3x3 every 30K miles....
I have an '08 with a bit over 4000 miles and 20% oil life left on my break in oil, so that first oil change is just around the corner. Do you recomend that I change the ATF already at what will be around 4500 miles? This would just be a drain and refill, right?
3x3 is for people who do the tranny fluid change after 30K - 50K miles.....just a drain and refill every oil change and you and your tranny should be in great shape even after years.....
are you serious?.. I started researching oil analysis on Z1 after even 12k miles. The aluminum & iron content starts to climb, the color starts turning dark and the flash point drops up to 30 points in those few miles. I talked to a local Master Tech and they won't touch a transmission with 100k miles that has never been changed. While many Honda products have rigored the test of time & wear.. I wouldn't risk it with these transmissions. Look at the 2G design.. they even redesigned the 3G A/T in 07 and have scrapped the M/T because of the issues it has.. Mine went out around 80k miles.. the previous owner probably never changed it, but also probably ran the crap out of it as well.. just beware that the cheap & easy way may end up biting you in the ass.
To me it’s similar to the 3-5,000 mile oil changes that people abide by, and not the MID. Hey, if people want to change the ATF every oil change, or 20K, or whatever, that's their prerogative. I'm just abiding by the recommended schedule from Acura.
I’ll let you know if the trans dies.
My Maintenance Minder has told me to change mine twice since I got the car @ 74k miles. Where do you see a change interval of 100k?? I wouldn't let ANY trans go that long without changing the fluid unless it already had. Then I wouldn't change it at all. Just wait for the trans to fail and hope I had saved enough cash from skipped maintenance to foot the bill.
once the trans gets used to running on crap.. it won't run on anything else.
I compromise and change my ATF every 20k. By the time I get to 60K I will have done a 3x3 effectively but not wasted lots of 5 minute old fluid. I also get the benefit of seeing how much shavings are on the drain plug sooner than the normal 30-60k interval for a little piece of mind. I would hope the shaving amount degrades over time, but I guess I'll see when I hit 40K. There was a lot at 20k.
As I understand, the 3x3 method is only necessary when some incompatible ATF was used in a emergency situation. I haven't seen any reference in the Service Manual about having to do it on a regular basis. I think the recent information regarding replacing the AT sensors is a better long-term idea than a 3x3 for most people.
I can certainly understand why a dealer wants a customer to pop for the 3x3 because they can make some extra profit on the service.
Honcura in Glendale - Transmission fluid change?
I called Honcura in Glendale, CA to find out about the 3X3 transmission fluid change today. But, he doesn't seem to think that it's necessary.
I am pretty sure that he's an expert, or may be I just didn't mention it very clearly. He said he would replace the fluid with 3 quarts for $30.
Anybody brought their car to Honcura for this service?
must have been the service writer who is NOT a tech
the fluid alone cost 8 bucks a qt- so 6 bucks labor is a steal!!
honda/acura says the 3 qt drain and refill is ok
they only say to do a full change if you added other brand of fluid- dex3
Acura dealers have a new method with running the car on the lift and simulating the in between drives- to change out all the fluid
their tech department came up with the new method for the newer cars with a differant trans but it would work for gens 2 and 3 ok
Although that would be preventative maintenance, I think it would border on being compulsive. IMHO, changing your transmission fluid at every oil change is just a waist of money and time. The 3x3 at every 20-30k is more than good enough for preventative maintenance IMHO.
^^^ i use some new ATF fluid to clean the bolts out....also while draining the old fluid, towards the end i tend to put some new fluid in and watch it come out.....
then i tighten the bolts and I have around 2.5-2.6 quarts left
which i pour right into the tranny
Never had a trans failure in the millions of miles I've driven and the TL has the 7yr 100k warranty. The trans fluid is 100k unless driven under severe conditions, and then you're looking at 60K. Once again, the color is not an indication of the quality as the red dye will dissipate after use and the color change is perfectly normal.
In the end, it's the same except you freshen up the fluid continuously with the change every oil change. Honestly, the best solution is to use a good synthetic that won't cost you more than the Z1 anyway and change it at a conservative 50K.
It's funny you ask. I just had to do another drain and refill of the Amsoil ATD even though I was going to push it to 100,000 miles or somewhere close. My shift quality was going down and the fluid was black but with no metal or clutch material in it. I couldn't figure out why a premium synthetic went black in 30,000 miles, especially with a cooler. I swapped it out and the shift quality returned. Then I remembered 20K miles ago when the axles were replaced, they drained and refilled with Z1 even though I had a gallon of the Amsoil in the back seat that I told them to use.
So I guess the answer is that with good filtration (magnefine filter), a cooler, and a premium synthetic fluid I was planning on pushing it to 100K depending on how the magnefine filters looked when cut open.
my tranny fluid was changed 20 000km ago by the acura dealer (using standard honda tranny fluid I am guessing) and my shifting was smooth. but now from time to time I am having problems with my 3rd gear. This happenes maybe once a month where it's a little hard to get it into the 3rd gear. Do you think it's time for me to do 3x3 with GM Syncro fluid? I just wanna take every precaution to protect my transmision. And how often do you think I should change it (km wise not time wise)?
