Transmission fluid 2007 3.2
I drained tranny fluid and 4 quarts came out but the recommendation is 3 i think? I put 3 quarts in should it be okay with just or should i put the next quart in.
what does your dipstick say
![Poke](https://acurazine.com/forums/images/smilies/poke.gif)
When I do the 3 x 3 I get anywhere from 3 to 4 quarts out. Just measure and put back the same. I actually usually just slightly under fill (put back a little less than taken out) and then drive to get it warm and check with the dipstick. Add a little if stays low. btw I fill through the dip stick which is easier access.
thelastaspec
06-13-2011 12:59 AM
Putthead
01-13-2011 09:30 AM
silver01cltypes
08-12-2010 03:47 PM
idkjai
08-12-2009 11:16 PM
