Transmission cooler hoses
My transmission hoses that are at the bottom of the radiator are leaking. They look to be 3/8th hoses and there are I believe 3 or 4 of them. Can any 3/8th hose be used to replace these or are some specific hoses needed? Also are they all the same size?
What do you mean by that part? I did use screw clamps and I just tightened them at the ends.
With the open style worm drive clamps, some will crank them down so tightly that the rubber hose protrudes through the slots.
Personally, a little over kill, but on some applications I use lined or aviation clamps that have an inside smooth surface that contacts the rubber.
