Tranny fluid change at 17k????
#41
#42
#45
#46
^^^^^Thanks!
I'm planning to do a ATF drain/fill everytime I do my oil change at about 5k miles (I use mobil 1)...but after ther 3rd fill Im going to leave the synthetic ATF (either Amsoil or Redline) for a longet time period...maybe 30k miles or 4 years! Comments?
#48
Please read this thread to learn why.
The RR Journals: ATF drain and refill 3G Garage #C-012 (click here)
Be sure to see my post (Post #62 on Page 2) in that linked thread. This explains how your new fluid gets mixed with the old fluid.
#49
Those of you changing your synthetic every oil change, I only suggest that for Z1. It's not necessary to change the synthetic as often.
#50
Area on my XM
The TL tranny fiasco has yet to cease to amaze me. 15-20k change intervals for OEM "recommended" fluid is outrageous for any vehicle. I can't complain much about the problem, tho... I did not do my research on this before I chose this car. It was kind of an impulse buy. As much of a love affair I have with my TL, this information would have probably been a nail in the coffin for the car. I need to check the condition of my fluid now...
#51
For those thinking of switching to Redline D4, the link below is where I got mine. $99.99 for a 12 quart case. After shipping it came out to $109 and change. I got mine in 2 days, pretty fast shipping.
http://www.amazon.com/Red-Line-D4-AT...6536358&sr=1-8
#52
glad I saw this thread, I'm at 58,000 and thought it was good for another year, I can't believe people are doing it at every oil change, is it really necessary? My 07 tl-s still drives like the day I bought it but I'm taking it to the dealer as soon as posibble, this thread scared me straight
#53
oh and I never go into v-tec maybe twice in 3 years cause my wife grabs the door handle and sticks her legs out whenever someone cuts us off or drives by us really fast so I just promise to drive safe I guess its good for the car anyways
#56
2008 Acura TL Type-S
#57
Area on my XM
It was suggested to me to siphon the ATF with a pump from the dipstick tube under the hood. Thinking about this, it sounds logical since I have known people to use this method for oil changes. Has this been attempted? To be honest, I don't have the equipment or room to facilitate doing this myself the way it is described in the Garage.
Since I believe that this will be the first time the fluid has been changed (at 45k miles), I'm guessing that the filter should probably be replaced at this point? If that is this case, I'm going to leave the job to a competent transmission shop.
But, about the siphon method... Would that gain me satisfactory results for a DIY project in the future?
#58
I am just about to hit 12,000 miles on my 2008 automatic TL-S and it shifts into 4 gear a little hard. I have taken it to the dealership and they said there was nothing wrong. I was thinking about doing a 3x3 change at 15,000 miles and a 3x1 change every oil change. The every 15,000 miles do a 3x3 change. I know it is most likely overkill but I want to keep the transmission running as smooth as possible. What do you guys think of this plan?
#59
#61
Area on my XM
^ I haven't had a chance to try this yet, but it's in the works soon. I can't see why this wouldn't be as effective as draining it from the pan, with the exception that it's probably going to take longer and I will have no access to the filter (which probably needed to be replaced at this point). Let me know how you go about it.
#62
To those of you torn between the Amsoil and Redline D4, I honestly can't recommend one over the other based on shift performance. Keep in mind I've always run the ATD, not ATF because the ATD is a heavier duty formula and I've *heard* that it uses less FM.
Going by theory the Redline should be slightly better at slowing wear with it's base stock but who knows. It's safe to say that they both perform great.
#63
Area on my XM
Now, in regards to pumping the fluid from the dipstick tube, I would believe that I would get the same results (sans the magnet cleaning and filter replacement) as if I did a drain from the bolt if I was to do the same procedure one would use for the 3x3 flush (i.e., drain, add, drive vehicle using all gears, etc). It might take longer as I might be able to only get, say, two quarts out at a time, but this would probably be better than doing nothing at all. Am I right? Keep in mind that the reason behind this unconventional method is my lack of tools and workspace to do this myself.
mada51589
05-03-2022 08:54 PM
HeloDown
09-08-2015 06:51 PM
