Trade TL for an AUDI A3?
What do u guys think trade a TL for an audi A3?
the 2006 A3 comes with DSG Gearbox , double sunroof, better handling...
and (2.0T) 200HP is just good enought for that weight...
German car, better quality (well, at least no rattle) ...
smaller car, fun to drive.
any opinions?
ps: love the "big mouth"~
any opinions?
Better handling...definitely yes. Audi’s in my opinion are the best handling cars out there due to Quattro. No rattles - you got to be kidding. I used to have a 2002 A4 which I called the snap crackle mobile. Better reliability - probably not especially for a first year model car combined with the fact that Audi is at the bottom of the barrel for reliability according to consumer reports.
i think it depends on the tl...
6sp tl w/ aspec and ps2's = one of the best handling cars ive owned...including the s2k....
dsg is much smoother and faster than smg..it is considered more of an 'auto' than the smg...
http://mydreams.go.ro/art_direct_shift.html
Q: What does DSG stand for?
A: Direct Shift Gearbox.
Q: Is DSG just another automatic transmission?
A: Yes & No. DSG is something that has never been offered in production vehicles before and is a direct result of racing technology from 20 years ago coming down to consumer levels. When the DSG in "D" (Drive.) it behaves just like a regular automatic for the most part except that at a stop the car goes into neutral. When you start to ease off the brake, the clutch will smoothly engage just like a manual transmission. Drop the transmission in "S" for sport mode, the transmission is still in “automatic”, until you click on one of the paddles. In sport mode it’s very aggressive, the transmission keeps the revs in the optimum power band.
Q: How much with the DSG option cost?
A: Maybe about the same as a TriTronic transmission, $1200(?)
Q: Does DSG have a clutch peddle like a normal manual?
A: No.
Q: Can you go up to redline on the DSG with out ‘it’ shifting on me?
A: Yes you can go to the redline, but when you hit the redline it WILL shift for you to the next gear
Q: Does DSG shift slow?
A: No, in fact it shifts faster then a manual transmission. This equals better acceleration.
Q: How much more does it weight?
A: The DSG transmission weighs about 66 lbs. more than the standard manual MQ350 six-speed
Q: What about fuel economy?
A: Gas mileage is better than the manual transmission
Q: How much torque can a DSG transmission handle?
A: Right now it tops around 240lbs-ft. VW might create higher torque rated transmissions depending on the engine application.
Q: What if I want to add power upgrade to my car that exceeds the 240lbs-ft?
A: The entire system is electronically monitored and controlled via a mechatronics module inside the transmission. This module communicates with the engine ECU and other electronic systems as well. Because of this, it will make adding a forced induction system or any other heavy duty power upgrades extremely difficult next to impossible. You might be able to get away with minor power upgrades.
Q: How does DSG work?
A: Here's how it works (try to stay with us here): At a stop, the transmission drops into neutral. When you start to lift your foot off the brake, the clutch connected to input shaft 1 will smoothly engage moving the car forward much like a manual transmission except electronically and automatically. Input shaft 1 is now controlling first gear providing power to the wheels. While input shaft 1 is in first, input shaft two has selected 2nd gear in anticipation of the next upshift. When the transmission requests 2nd gear (either via the paddles, gate or automatically) clutch one opens up and clutch two engages in as quickly as .008 seconds. There is a certain amount of slippage in the clutches to ensure a smooth transition from gear to gear. In the event of a downshift, the transmission will request a throttle blip from the engine ECU to match revs and then shift down a gear - this happens in as quick as .6 seconds including the throttle matching. The transmission can even shift from 6th to 2nd gear without having to sequentially run down through every gear. In this case, DSG will switch input shafts from 6th gear going to 5th temporarily on input shaft 2 and then into 2nd with input shaft 1 while blipping the throttle to match revs - all in less than .9 seconds.
http://forums.vwvortex.com/zerothread?id=1779303
and the quattro a3 wont be here until next year.
A: No.
isn't the A3 just audi's version of the golf? the TL is a much larger sedan and not really in the same class as the A3(maybe just price wise). it looks way to small to consider it as a replacement or trade for the TL. if i were to get a 2 door i would probably get the G35 coupe instead as that looks like a better deal than tha audi.
I think it's so eye-catching because of its DSG tranny. This is what Motortrend said: "...with the sublime 3.2 DSG Quattro setup. Backing either engine, DSG behaves just like a conventional slushbox in "D," but in "S" it shifts as you would, rendering the steering-wheel paddles almost unnecessary..." http://motortrend.com/roadtests/wago...udi/index.html
Try to test SMG and DSG cars, you will love them. IMHO...
Base price: $25,000 (est.)
Engine: turbocharged 2.0-liter in-line four, 200 hp/207 lb-ft
Drivetrain: Six-speed manual or DSG, front-wheel drive
Length x width x height: 168.7 x 69.5 x 56.0 in (77.1 inches wide with mirrors)
Wheelbase: 101.5 in
Curb weight: 2900 lb
EPA City/Hwy: 19-20/26-30
Safety equipment: Anti-lock brakes, traction control, stability control, dual front and side curtain airbags, tire-pressure monitor
Major standard equipment: Dual-zone climate control, power windows/locks/mirrors, cruise control, AM/FM/CD player anti-theft system, pre-wiring for satellite radio
Warranty: Four years/50,000 miles
Originally Posted by deandorsey
...and the quattro a3 wont be here until next year.
Originally Posted by rets
A3 is Sportback sedan, 4 drs. The first model in US Audi's lineup is I-4 FWD. (V-6 3.2Liter or Quattro won't be here until the next fall, 250 hp/236 lb-ft)
Wheelbase: 101.5 in
Wheelbase: 101.5 in
no thanks doesn't strike me as something that i would consider purchasing. i am not a big fan of the station wagon type cars. i am aware of the SMG type trannies but still not a big fan of them. like i said the lack of a clutch pedal makes the car feel like it's missing something. i prefer the individual gates for each gear as opposed to sequential gearing. but who knows my tone may change later as more and more cars come equipped with this type of tranny especially higher end sports sedans.
two totally different cars. Are you willing to lose the space from going to a smaller car?
If fun is the main reason then i think the A3 will be a blast. I got to sit in one at my last track event. The seats are soo nice, they hug you down. Quattro wont come for another year and i personally think the price they are asking is too much. But im sure it will be a blast to toss around.
Originally Posted by bayTL
I just got back from Switzerland and saw the new A3 and the new GTi. Not bad looking in person for that type of car.
I don't see the parallel between that and the TL. The TL is a mid size sport luxary sedan. The Audi is a upscale GTI a pocket rocket car that has a station wagon body( more subaru like). Not the same type of car. If you want that type of car get a S2000 (pure sports car) or a WRX the wagon with some mean performance. The TL is a great enrtry lux cruiser with excellent performance.
I was considering waiting for the A3 but the lack of Quattro and having to wait until mid-May made me go with the TL. I had an 02 A4 and considered the new A4 but costs were hihg. The A3 is an excellent car; if you can wait for the Quattro and get the DSG, I would do it over the TL.
As far as rattles and cost, I have owned 2 VWs, an Audi and they have been no more expensive than the Honda, Infiniti FX and TL. The FX was very expensive to run/maintain. My current TL, which is 1 month old today with 3300miles, already has rattles. I love my TL but I am not sure why the bad blood towards Audi.
where'd you go in Switzerland...i grew up there, moved in fourth grade
Hell No
If you go to the audi website and start config?ing that A3 they charge you extra for every single detail extra;; . . xenons, rear Airbags, gearbox, on the last page you have a bill for 35K ,,come on boy !! dont even think about it. That's a Pear White Tl with navy ., all you need it's tint, aem air flow, and eibach pro suspension pack .. . .with an A3 you'll get an small car ,. Think how this car will handle a heavy accident,. TL alrady comes with standars like xenon, side airbags for no exta cost,., and of Course a Baseline Heavy car with SAFETY Passed A+..
I think I'm at least the third person in this thread who had an '02 A4 before my TL.
That Audi was the best car I ever owned, bar none. My only real complaint was that the 1.8T was underpowered, for a 3300lb car.
Trading it for a TL was a big mistake; I noticed rattles on my way home from the Acura dealership.
.....You try and sample things and then back to what you like...It costs some dough, but that why I went to school..earn money and have fun with it...
mlody
Dec 4, 2019 02:11 PM
But that FWD A3 looks lighter and less-power... Not sure. Have to test-drive it.
