TPMS is a bit annoying in cold temps
#41
Thanks for clearing that up a little Mike03a3. By no means was I advocating the use of nitrogen, in fact if you are paying someone to put nitrogen in your tires you might as well throw the money in the fireplace. Honestly I just cut an pasted the first little bit of info I came across without really reading it.
Most commercial Nitrogen generators I've seen only produce about 95% pure nitrogen. The generator we have at work will do 99.9% pure and we use it for the exact reasons you stated.
If anyone has access to free nitrogen, I'd say go ahead and use it, but please don't pay for it. You are just wasting your money.
#42
Originally Posted by MisterFubar
[1] Nitrogen is denser than Oxygen: This means the larger
molecules escape less easily from tires resulting in a more
gradual loss of pressure over time. According to the Michelin
Tire Manual, a tire that is inflated with Nitrogen loses its
pressure 3 times slower than if it were inflated with air.
[2] Nitrogen is moisture free: Pure Nitrogen inflated tires
experience less steel belt and rubber degradation. Nitrogen use
also reduces valve and wheel corrosion.
[3] Nitrogen provides longer tire life: Nitrogen inflated tire
run cooler and require less maintenance according to the Goodyear
application bulletin.
[4] Nitrogen is non-flammable: Nitrogen technology has been used
in aircraft, military and race car technology for over thirty
years."
years."
2. OK. So let me get this straight. Most people probably drive through water or rain what, every other day or so? The outside of my tires are completely covered in water half of the time but I'm supposed to worry about 1 part per million of water inside the tire? I don't understand. Also, the tire will go bald WAY before you have to worry about the steel belt rusting because of water inside the tire. Pure bull$hit.
3. That makes absolutely no sense whatsoever. The medium inside the tire will NOT change the amount of sidewall flexing or road friction imparted on the tire- the two main causes of tire heatup. Less maintainence? So if I put nitogen in my tire, my car's alignment will suddenly magically be perfect and I won't need to rotate my tires as much? I guess putting nitrogen in the tires also magically makes them perfectly balanced. Bull$hit.
4. Ah, of course. Because regular air is so combustable, it's a fire hazard. I guess they assume if you aren't filling your tires with nitrogen, you must be filling them with kerosene. Bull$hit.
#43
Originally Posted by jzacuto
Sorry to sound like a simpleton, but isn't the general rule (and isn't this published in Acura tech pubs) to always measure tire pressure when the tires are warm? So if the TPMS is registering low (and you don't appear to have a flat tire) and you drive a bit and the pressures come up, everything's pretty honkey dorey.
#45
CTS-V Import Slayer
Originally Posted by Desert_TL
1. What mike said (right on brotha). Pure bull$hit
There is limited benefits to the use of nitrogen, this has been proven. Yes....there is less likely to be water, ect inside the tire, ect meaning a rim wouldnt rust, ect. but you are kinda right...you are more likely to wear out the tire before this is a problem and switch it out. I think the greatest benefit to using pure nitrogen is less pressure variences in the tires...and less natural "leakage" of pressure...but outside of that....benefits are very minor at best...and certainly NOT worth paying extra money for as usually normal compressor air has a fairly high percentage of nitrogen in it to begin with....(like 80% or something like that...but going by memory here). Matter of fact...will search on another site here real quick and post up the response my buddy gave...AND HE WORKS FOR A GOOD SIZED TIRE COMPANY...
(START PASTE FROM MEMBER SPOOLIN'ONYOU FROM ANOTHER SITE)
Background: this was a response to a member talking about the Acura Service Bulletin that came out referring to limited benefits of nitrogen in tires....
Benefits of N2 is debatable. The company I work for has recently invested a LOT of money changing all the stores over to Nitrogen Inflation Systems. Nitrogen isn't affected by change in temperatures. The molecules are larger so it doesn't seep through the tires as easily. Nitrogen is purely dry air.
That article is mostly correct, however, they did compare N2 to 'dry' compressed air. Having N2 in a store such as mine is more of a benefit than a hassle. Since the air comes out dry, the inside of the wheels don't corrode from moisture, which is good. Corrosion causes bead leaks...which in turn makes more work for my guys...
We've got a Nitrogen monitor at work. Yes, the air you breathe is roughly 80% Nitrogen. Our monitor stuck into free air reads 82% usually. When put on the valve stem of a tire that we've inflated with Nitrogen, it jumps to right around 98%.
And what a lot of other tire companies will tell you is that you can't add regular compressed air to a tire that's been filled with Nitrogen. WRONG! If your tire pressure has went down, you can add regular compressed air to it without affecting the tire. The Nitrogen percentage will go down, but not much. Why? Remember, regular compressed air is roughly 80% Nitrogen anyway.
Roughly every 15 years, the Nitrogen fad comes and goes. I'm sure you'll all see it fade out within the next year or so, then in about 15 more years, they'll come out with Nitrogen again, as if it's the greatest thing on earth. Trust me, just watch.
Oh yeah, and if you've bought tires, had a tire repaired, or just had your own tires mounted up from us since August, your tires are inflated with Nitrogen.
(end paste from Spoolin'OnYou)
Kind of interesting isnt it? In my opinion...kind of ends the argument. Yes...its a good thing....but benefits are kind of limited to some degree and not worth paying extra money for unless its part of the deal! Now if you are truely racing in a competition atmosphere on a track and often...maybe I might say spend money....but probably not as most compressors have driers on em to begin with that is there to wick out moisture and it readily available about everywhere. Basically....Nitrogen is a good thing...but not the save all to end all here in my opinion as the air you breathe is roughly 80%?
#46
Terminex
A couple items to consider
- Fill your ties if they are low no matter what the temp is.
- if cold fill to 32
- if the tires are warm (i.e. driven on for at least 15 minutes straight) - fill to 36 (the rule is 4 lbs of pressure for warm vs cold)
- Do not waste your money on the nitrogen (it will take 3-5 COMPLETE deflations / infrations to get them about 4 - 8 % better nitrogen content than regular air.
- Snow is SIMILAR to off road conditions - i.e. lower tire pressure will give you a greater surface area= greater contact patch. (you are really better off having the tires inflated properly so that you never damage the rims / sidewalls - off road tires and wheels are designed to run lower pressure - I run the tires at about 12 to 18 PSI in my Pathfinder when 4 wheeling - you will damage your rims if you try that with your TL)
- Ice = normal or slightly higher tire pressure. (although I do NOT recomend driving on ice, you want the most weight on the smallest contact patch available. this puts more pressure on those 4 points allowing better traction)
#47
Originally Posted by niti
Can you tell me more about the "line-dryer" apparatus? Where to buy, how much etc. That sounds like a great idea if it's fairly inexpensive. Is it something that you just pick up at home depot? Did a search on the home depot site and came up empty.
found this on ebay is this similar to the one you bought?
http://cgi.ebay.com/ebaymotors/AIR-...5QQcmdZViewItem
But yeah, this is exactly like the one I got... I bought mine at Home Depot or Lowes, I can't remember which. But I remember they didn't have it online, but I found it in the store. It was like $10 or something like that.
They sell more expensive/exotic looking line-dryers that use the same dessicants that you find in those "Do-Not eat" packs, but the one mentioned above worked well enough for me, as after using this to fill my tires, the TPMS never gave me any more issues.
#48
RAR
One piece of advice, the manufacturer recommends checking and filling at cold because they know that as you drive it, the tire will expand and at high speeds, the tire will reach its optimal inflation point (like 35-38 or so), if your tires are at 28 or less, this is truely on the low side, and you will experience premature wear and tear, as well as lower handling, performance, and fuel efficiency. If you switch to Nitrogen, you should go ahead and pump it up to 35-38 as your tire will already be at the optimal psi regardless of temp.
#49
Mike's Silver Bullet
#50
The Max Pressure given on the sidewall of the tire is a Never Exceed pressure. On my Michelins, I think it is 45psi. That's one of the things I find useful with the TPMS: I can observe the air pressure while driving. Usually it goes up to about 40psi while driving since I keep my fronts at 36, rears at 34.
#51
Originally Posted by sandynmike
Temperature will have the exact same effect on tires filled with dry nitrogen as those filled with dry air. (PV=NRT). When using either, you should fill to the pressure recommended for the vehicle, cold.
Fill up to 32 psi cold on AIR, Nitrogen, Hot or cold.
#52
Originally Posted by pimpin-tl
Temperature will not change the PSI if Nitrogen is filled in the tires. I had some wheels and tires filled with Nitrogen, if it was 25 degrees out or 100 the psi still stayed the same.
most gas station air-compressors have so much water in the tanks it's not even funny...
BoricuaTL
04-08-2016 01:08 PM
CheeseyPoofs McNut
10-11-2015 11:25 AM
