Torque wrench for TL?
Old Jun 27, 2009 | 10:22 PM
twopu's Avatar
I need to pick one up for my lawnmower. I'm looking at a craftsman beam torque wrench 0-75 ft lbs but I'm wondering if I'll need to go higher 0-150 ft lbs for anything on the TL? How much do the lug nuts need? I rarely have a need for it, just get tired of borrowing it once or twice a year, so I don't want to spend a lot.
Old Jun 27, 2009 | 10:47 PM
jguerra23's Avatar
Looking for new mods
Yup need more since lugs are typically 80lbs.
Old Jun 27, 2009 | 10:54 PM
LaCostaRacer's Avatar
I believe the lug nuts are torqued @ 80 lbs. I bought my torque wrenches at harbor freight and they are great! I recommend the 1/2 inch for wheels and it runs < $25 at Harbor Freight. The 1/2 range is 20-150lbs and tbhe 3/8 is 5-80lbs. I wound up getting both for < $50 three years ago and they have come in handy many times: tire rotates, sway bars, drain fill bolts, etc.
Craftsman seems to have taken a big hit in quality when I was shopping for a torque wrench so I decided to give the Harbor Freight tools a try and couldn't be happier.
Old Jun 28, 2009 | 02:51 AM
avs007's Avatar
Also, the brake caliper bolts are 125 pound ft. (If you have the brembos)
Old Jun 28, 2009 | 06:39 AM
Japspec954's Avatar
Man, sounds like I need to hit Harbor Freight up. That sounds like hell of a deal!
Old Jun 28, 2009 | 11:41 AM
BradE's Avatar
I have a Snap-On that goes up to 80 ft/lb's. For anything high I bought a cheaper one from Harbor Freight since I don't have a regular use for a 1/2" drive torque wrench.
Old Jun 28, 2009 | 11:42 AM
BradE's Avatar
Damn, that is a lot for caliper bolts.
Old Jun 29, 2009 | 05:09 AM
SouthernBoy's Avatar
Registered Member
I have three. One is measured in in/lbs and is the one I use for my TL oil changes exclusively because it is shorter and therefore clears my driveway when using it. The other two are max 100 and 150 ft/lbs respectively.
This highest torque bold spec I know of on the TL is the crankshaft bolt that secures the belt pulley. It is 180 ft/lbs as I recall.
Old Jun 29, 2009 | 11:36 AM
For those of you going to Harbor Freight, here are the must-buys related to the torque wrench:
1/2 inch impact drive lug nut (metric) socket kit - forgot price but < $20.
1/2 inch breaker bar - somewhere around $10
Socket adapter kit so you can use your 3/8 sockets with these new 1/2 inch tools
For less than $40, you'll be set!
Old Jun 29, 2009 | 01:50 PM
NAiL05's Avatar
Just saying in harbor frieght ads they have a +/- 6% accuracy on reading in the ad lol but I assume thats over time which I found kinda funny (I shop at hf occasionally...They make good breaker bars and pry bars lol). Anyway I have like 20 or so tq wrenches sitting at home ranging from in/lb to ft/lb lol. I usually use the 150ft/lb half inch drive most of the time. Usually bolts in the engine bay I snug unless it is a critical component that needs torquing.
knight rider
Mar 4, 2016 08:59 AM
joflewbyu2
Oct 8, 2015 11:16 AM
Skirmich
Oct 1, 2015 12:59 PM
hpfiend
Sep 27, 2015 06:59 AM
Rcelestino93
Sep 23, 2015 10:01 PM
