TL-S rotor size
TL-S rotor size
hi guys, i got some question of tl-s 07 rotor. i just got tl-s and had inspection last week but its failed because front rotor was too thin. so i went to dealer and request replace to new one. but dealer said tl-s has thinner rotor than base model so it's probably inspector has wrong measurement. i call inspector again and told him that what dealer said. but inspector said. tl-s m/t use thinner rotor but a/t use same size as base tl. i was also looking base and s model spec on web site. it said base model use 1.1(28mm) thickness and s model use 0.98(25mm) thickness but it doesn't said a/t or m/t. i don't know who is right and i need to figure it out first before go to dealer. so please give me information for rotor.. please..
AZ Community Team
Received 7,770 Likes
Type-S AT & MT are the same brakes. EXACTLY the same.
Also ALL 2004 - 2006 MT are EXCATLY the same brakes as ALL 2007/2008 TL-S.
Stock thickness new = 0.98 inches.
http://www.hondanews.com/channels/ac...specifications
From the 2004 Service Manual (remember brakes for ALL '07/'08 TL-S are the same as brakes for ALL '04-'06 MT):
- Front Discs TL - Ventilated, 11.8 in (300 mm) diameter; 1.1 in (28 mm) rotor thickness
- TL Type-S - Ventilated Brembo, 12.2 in (310 mm) diameter, 0.98 in (25 mm) rotor thickness
- Rear Discs Solid, 11.1 in (282 mm) diameter; 0.35 in (9 mm) rotor thickness
AZ Community Team
MetalGearTypeS
08-29-2016 08:28 PM
ExcelerateRep
10-14-2015 08:20 AM
