TL Compression
Old Apr 8, 2010 | 06:51 PM
vovka2007's Avatar
TL Compression
Almost hitting 140k on my car. Car running strong. Since i love it so much i decided to do Seafoam to it. But before i do it, I'm planning to check the compression on each cylinders. And then maybe do the test after seafoam. Anyone knows the compression specs for out car? What should i expect?
Old Apr 8, 2010 | 08:13 PM
94eg!'s Avatar
#1 Super Guy!
135psi with a variation of 28psi between each cylinder. This is to be checked by cranking with the starter. FYI: It's much lower than typical for an 11:1 engine because the throttle will be closed since this car has an electronic throttle.
I have no idea how you disable the injectors to crank the engine though...
Old Apr 8, 2010 | 08:25 PM
Crestwood1001's Avatar
Pull the fuse for the fuel pump, that way u can crank it
1fatcrxnem1
22
Jun 1, 2018 01:23 AM
mossman77
1/2G MDX (2001-2013)
18
Sep 16, 2015 12:21 PM
Sep 13, 2015 01:59 PM
