TL in an accident
Does that mean the paint job (finish, gloss and durability) done by a reputable bodyshop is equivalent to the factory paint job? I am not sure I want to damage the factory paint while blending in...hopefully the difference will not be too noticable? They do detail the car, however I was not sure if it should be done immediately on a new paint job? to the best of my knowledge they send it to a detail shop nearby.
The rest has to do with the quality of the painter. If they do a good job you may not notice it at all. For a bumper I think you will be OK.
OP, seems like you're in the Chicago area (I noticed your Mullers license plate frame). Two years ago I purchased an OEM rear bumper cover myself and had Dent Mob in Schaumburg repaint and mount it. It was inexpensive and the paint match was perfect. Better than the original bumper. Paint has held up nicely. I have also used them a couple times on various vehicle to do Paintless Dent Repair.
If done correctly there really should not be a difference or at the very least it will be minimal. The problem is that over time the paint on your car will weather and fade. The paint code used by the paint shop will be the unweathered color and so if your paint is new then the match is better than if it is faded.
If you want a great body shop check out A&L in Palatine. I was there today for the first time with a buddy to get some work done on his Miata. They really took there time to explain the work that would have to be done. They are also very well known on the Euro forums as there was a bunch of M3's, M5's, Porsche's outside and a R8 inside that they were working on.
http://www.yelp.com/biz/a-and-l-autobody-palatine
What do you guys think? Is fixing better than replacing or vice versa for a perfect match, finish and fitting? anyone has any experience with a fixed bumper?
Also not sure if this is the right place to ask but I have added pictures of other cars involved a lexus and a chevy. The chevy has little to no damage however the estimate to fix the lexus is $4000 dollars - does the damage look worth $4000?
Thank you for all the advice!!
No problem on recommending the shop.
Did Anthony recommend going the "fix" route? How much was the price difference on getting it replaced? If it isn't much more money to replace it then I would just do that.
BoricuaTL
Apr 8, 2016 01:08 PM
Ponsey_Scheme
Oct 23, 2015 09:16 PM
