Timing Belt Special still going strong @ $299 shipped
WholesalePartsGuy (05-01-2012)
#82
Former Sponsor
Took our '04 TL to the dealers to do the oil change. We're at 94K. Next visit he says should do our 105K service $2k....Oil leak somewhere near the timing case, 1k for the seal. Will cost somewhere near $3K for the "package deal"!
RIP OFF OR WAT?!
RIP OFF OR WAT?!
The following 2 users liked this post by roat41:
HAWAIIS FINEST (01-26-2012),
WholesalePartsGuy (01-30-2012)
#93
Wow this seems like an awesome deal, this almost beats out my employee discount from the large auto parts retailer I work at and this is factory stuff not random brands!
Could you quote me the timing kit, with idler pulley, front brake pads and rotors(6speed) and a thermostat.
I would have PM'd you but then everyone else won't get the benefit of my quote!
2004 A-Spec
2004 A-Spec
#94
why are these prices drastically different from:
at https://acurazine.com/forums/3g-tl-2004-2008-93/cheap-oem-timing-belt-kits-846127/
Just wanted to offer a special Timing Belt Kit for all 2004-2008 Acura TL and TL-S cars. Here are the links. Let me know if you guys have any questions
http://www.performancepalace.com/200...TIMING-KIT.htm
This is with the tensioner
http://www.performancepalace.com/200...MING-KIT-1.htm
This offer is only good until Feb 29th so get them while you can
#95
Former Sponsor
There is a tensioner missing from that kit that you really should not do this job without. It's called the timing belt adjuster and the list price is $107. I think he is trying to short cut it to beat my price. Be carefull!!
#97
#98
2006 Acura TL
Looking into getting the complete kit from you. I'm at 117,xxx miles and am in need of a major service. What other parts would I need? I already replaced my breaks so won't be needing brakes.
#99
Former Sponsor
Besides the timing kit and fluids (atf, coolant, brake fluid), the only other things you should replace if you haven't already are the plugs, valve cover gaskets and spark plug seals, (replace during valve adjustment) and whichever filters you are due for (oil, air, cabin). I've got all that stuff in stock and can make you a good deal especially if it ships together.
#103
I know I posted in the CL post but ill do it here too to get more specific.
I am doing the valve adj and the timing kit.
I already replaced the serp belt and the spark plugs. So without those can you shoot me a price shipped to 16504?
Thanks!!
Thanks!!
#104
I'm still kind of confused everything I need for the 105k is in this kit already? I heard something about t stat seals gaskets? I already got fluids and the spark plugs thanks larry shipped to 92117
#106
Former Sponsor
So if I take out the serp belt and put in 2 valve cover gaskets you are looking at $299 shipped.
#110
Q('.')=O
Hey Larry it looks like I am going to order from you after all but I have a question first...
So it looks like there are a couple 105k timing belt packages you are offering.
1) Timng belt, water pump, both tensioners, and drive belt for $320
2) All the above plus spark plugs, idler pulley, and thermostat for $450.
(Am I correct about the parts and prices?)
My real question, is it recommended to get the extra stuff (plugs, pulley, thermostat) too or does it make a big difference?
#111
Q('.')=O
Never mind again.
Last ditch effort I found a very reputable Honda/Acura shop that with parts (timing belt, drive belt, water pump, tensioners, spark plugs) and labor for $625. A steal! My mind it set.
#112
Former Sponsor
Hi, I am checking to see if there is any interest in a full kit ? Idler, thermostat ,cam seals,frontcrank seal, valve cover gaskets and plugs and sparkplug tube seals this would be added to the existing timingbelt kit we already offer. IT would be 491.00 SHIPPED
#115
could you let me know what the price for the following items would be shipped to 43614:
Timing Belt 14400-P8A-A02
Timing Belt Tensioner Pulley 14510-PGE-A01
Timing Belt Idler Pulley 14550-P8A-A01
Water Pump & Gasket 19200-P8A-A02
Power Steering Belt 56992-P8A-A01
Auto Tensioner 14520-P8E-A01
Thermostat 19301-P8E-A10
Valve Cover Gaskets
Plug Gaskets
Valve Cover Gaskets
Plug Gaskets
#117
I would like to know if you can give a price shipped for these parts. They are for an 08 TL-S 5 Auto.
Timing Belt
Water Pump & Gasket
Power Steering Belt
A/C / Alternator Belt
Auto Tensioner
Thermostat
Timing Belt
Water Pump & Gasket
Power Steering Belt
Auto Tensioner
Thermostat
#118
Its good to be FRESH!!
WholesalePartsGuy (05-08-2012)
#119
I guess I should have put it in my last post. Shipped to 87121. Thanks.
#120
Former Sponsor
Hey Sinistr, sorry for putting you on hold there but we a back in the t/belt business for the summer. The price for the kit you are requesting would be $385 shipped to your door.For everyone else, we are back to offering the original timing belt kit for $299 + $20 freight in the U.S. Have a great summer!
