Timing belt pulley question
Old Mar 11, 2017 | 10:23 PM
rimike's Avatar
Today I was changing the timing belt, pulleys and water pump. I took off the small pulley that is mounted just below the water pump. The bolt that holds it has a round taper under the head. When I took it apart to install the new one I wasn`t sure if I dropped a spacer or not? Besides this small pulley and the bolt is there any kind of spacer that should be there? I installed the pulley with just the bolt, it just seems wierd that there is no spacer. Tomorrow I will be finishing the job, I haven`t installed the new timing belt yet. Thanks for nay help.
Old Mar 12, 2017 | 09:13 AM
rimike's Avatar
Oh yeah, the car is a 2006 TL. Someone please chime in, I have to put this all back together today.
Old Mar 12, 2017 | 10:21 AM
nfnsquared's Avatar
The answer to your question is at the end of step 8 of the first post in this excellent thread:
https://acurazine.com/forums/third-g...ics%2A-784622/
If you have any more TB questions, you should post them in that thread. Good luck!
Old Mar 12, 2017 | 10:54 AM
rimike's Avatar
Thank you!
