Thoughts on Seafoam?
Old Jul 14, 2016 | 05:54 PM
L1GHT's Avatar
8th Gear
I recently bought a 2008 TL with 97k miles and I am thinking about doing a seafoam treatment. I did not see a thread about it anywhere. What does everyone think?
Old Jul 14, 2016 | 05:56 PM
Never heard of that stuff, what is it ??
Old Jul 14, 2016 | 06:08 PM
L1GHT's Avatar
8th Gear
It's basically a petroleum based engine cleaner. It's supposed to get rid of deposits and buildup. I have used it in other cars.
Old Jul 14, 2016 | 07:13 PM
ggesq's Avatar
Welcome to the forums.
Here's a thread from the 3G Service Department. It has tons of good info: https://acurazine.com/forums/third-g...ically-638069/
Old Jul 14, 2016 | 07:54 PM
nfnsquared's Avatar
OP, no harm in using but probably not needed/overkill if you run Top Tier gas....
Old Jul 14, 2016 | 10:11 PM
GreenSpades's Avatar
A VTEC a day keeps the seafoam in the bay.
Old Jul 15, 2016 | 12:29 AM
L1GHT's Avatar
8th Gear
Thank you everybody for your input
Old Jul 15, 2016 | 02:32 PM
UlsterBoy13's Avatar
Put a can in with 8 gallons of gas, run it to empty, add another 8 gallons of gas to use up the reidual seafoam without diluting it too much.
Do it again in 1000 miles. cleans it out nicely.
Dont do the crank case method, if you really think thats gunky buy some Auto-rx and run it for 3000 miles.
Old Jul 15, 2016 | 06:21 PM
nothome17's Avatar
These cars don't have carb build up issues but if you have time why not.
Old Jul 15, 2016 | 08:10 PM
bakaryu18's Avatar
Before my first oil change I put seafoam in my vacuum line, gas tank, and crank case. Reset the ECU, gas pedal method.
I have also been religiously using Marvel mystery oil, Seafoam, and Lucas fuel injector cleaner in the gas tank for about 5 months, every time tank is half full also put it in before the next fuel up.
Now I can run my car 340 miles before the low level gas light warning turns on. when that happens I fill up about 14 gallons of gas every time.
Car is NOT tuned either and do not have all my beneficial mods installed.
Old Jul 18, 2016 | 08:44 AM
Wow that's a lot of different snake oils
Old Jul 18, 2016 | 09:14 AM
Jackass's Avatar
So all of this to get to 24'ish mpg? Unless that is pure 25mph city traffic, that is a lot of work to get to that MPG. I have used Seafoam or Techron in my TL I think three times in the past 8 years, and I get the same if not better MPG than that.
Summary:
- if you use Top Tier gas all the time, it is unlikely you will ever need to use Seafoam or anything else in the fuel system
- if you are a new owner, it probably won't hurt to run some through the first tank or two since you have no idea what gas the previous owners used
- to each their own on what mystery snake oil combos you want to run...it is doubtful most of them will hurt your car.....just maybe your wallet a bit
I do use MMO and Seafoam in my mowers on a regular basis...just not my cars. I also do use Techron in my cars usually when we get back from vacation and had been putting unknown quality gas in. To note...that is rarely my TL...it is usually my wife's car since it is bigger and doesn't require premium.
Old Jul 18, 2016 | 12:24 PM
bakaryu18's Avatar
It's really not that much work, and doesn't cost much considering how long they last me. I think it's worth it because ever since I've used it my mpg have increased after every fill up since purchasing the car till now. It's starting to taper off though... However, that wont stop me from using it when I feel my engine innards need lubricating.
I don't have a lawn mower because I don't have grass, but I do have a weed whacker and I plan on using a small quantity of mmo and seafoam in it. Even though I've used it 5 times in the past 2 years.
My weed whacker is great on gas too, 4 hp, plan to modify it soon... just kidding. lol.
I drive my car about 70% city and 30% highway these days. About 230 miles of my fuel is used for the city and the rest is highway.
Old Jul 18, 2016 | 01:12 PM
DBConz's Avatar
Registered Idiot
i hear dealers tend to do a treatment before checking valve clearance.
i run them in all my bikes. i would run it through my TL every few months. as soon as i bought my used MDX, i put SeaFoam in it for the first two fill ups.
and for the person that said it's overkill if you're running 93 octane, you're wrong. it cleared up a spray issue on my injectors on a bike that's only had 93 octane.
Old Jul 18, 2016 | 01:20 PM
Jackass's Avatar
Fair enough...and what is key here is that this is all personal preference. Some people report improvements, some don't....everyone has their own "methods" on some of the mixtures, timings, and processes. I know since I was a kid, my father and grandfather all used MMO in everything. Same with adding ATF to your oil and/or pouring it into the carb to "clean" the engine. I even recall a thread in the past few years of people putting 2-cycle oil into their gas for similar "gains".
Old Jul 18, 2016 | 02:14 PM
Mykizism's Avatar
Garage Park / Ikon
Seafoam is great stuff, you can out some in your oil, fuel, intake with no adverse affects.
Seafoam is definitely not snake oil, it restores oxidized metal. I use it to clean all my engine / metal parts. It literally will eat rust away on a rusty part.
It will break down carbon deposits if you allow anything to soak in a bath of seafoam.
Old Jul 18, 2016 | 02:16 PM
was referrign to this little fella
Old Jul 18, 2016 | 02:21 PM
Mykizism's Avatar
Garage Park / Ikon
^ Agreed, 89, 91, 93 octanes doesn't matter what octane you run, you are going to build carbon deposits regardless. 93 octane does not necessarily mean it is cleaner than 89 octane.. it just an octane rating.
Old Jul 18, 2016 | 02:22 PM
bakaryu18's Avatar
seafoam!!
Old Jul 18, 2016 | 02:23 PM
Mykizism's Avatar
Garage Park / Ikon
Ahh, I have never used marvel mystery oil before, though I have seen it on the shelves, never personally used it myself so can't comment on MMO!!
Old Jul 18, 2016 | 03:16 PM
Oh Sickest TL's Avatar
Jeff
do you put this in your butthole?
Old Jul 18, 2016 | 04:32 PM
E39's Avatar
E39
Isn't there a belief that seafoam is bad for the seals and rubbers inside the engine if ran through the intake?
Old Jul 18, 2016 | 05:19 PM
L1GHT's Avatar
8th Gear
Very interesting... I would love to get that kind of mileage.
Old Jul 19, 2016 | 01:23 PM
according to the trip computer i recently got 29 mpg on a trip to OKC and back twice in 2 days, all highway, 70-80mph....
Old Jul 19, 2016 | 08:08 PM
LeVeL's Avatar
Both of these ^^^ My gas preference is Shell, ExxonMobil, Sunoco; daily doses of VTEC.
Strictly highway, cruise control, AC on, varying grades:
Typical average with 95% highway driving (faster cruising speeds, some in-town driving) is 33mpg.
Old Jul 20, 2016 | 07:11 AM
That be some good MPG there for those 13 minutes.
Old Jul 20, 2016 | 07:28 AM
Old Jul 20, 2016 | 09:15 AM
truonghthe's Avatar
not sure what seafoam can offer you but I got 28-29 MPG (no seafoam) from NY all the way down to Houston TX. Keep in mind I do have stuff inside the car while moving and weight around 275 lbs.
Old Jul 20, 2016 | 04:27 PM
LeVeL's Avatar
I averaged 34mpg over ~360mi but, predictably, don't have a pic.
Old Jul 20, 2016 | 04:31 PM
Old Jul 20, 2016 | 05:03 PM
LeVeL's Avatar
I'll get one next month when I'm driving out to Detroit!
Old Jul 20, 2016 | 05:47 PM
E39's Avatar
E39
I've noticed at 55mph an average of 33 to 35mpg is possible. Anything higher than 60 to 65mph the rpms climb and mpg drops to about 30.
What about Mopar combustion chamber cleaner, anyone ever heard of that? Supposed to be better than seafoam I hear. Only thing I'd be concerned about with these cleaners is if they may possibly be bad for engine seals etc.
Old Jul 20, 2016 | 06:17 PM
ggesq's Avatar
Seafoam is a waste of money if you're using quality fuel. It might possibly be useful in an old carbureted car with lots of miles on it. When I had my valves adjusted for the first time (original owner) at 200k miles (currently at 213k miles), the piston tops had virtually no carbon. The smoke one might see is the seafoam itself burning. Carbon can't 'reburn' and the minute amount that accumulates in the combustion chamber would not be noticeable out the tailpipe.
Old Jul 20, 2016 | 09:03 PM
So I checked my trip computer after work....not bad for Texas summer. And this is just my regular commute, mostly highway with a few snarly interchanges everyday slowing me down.
6.45pm and registering 99 degrees!!
Old Jul 22, 2016 | 03:14 AM
winkyyy's Avatar
I tried it before, half a bottle in the vacuum hose and the other half in the gas tank with a few gallons in there. Smoke came out after driving it around the block. As far as performance feel, it feels the same. I have yet to do it again since I have a spare bottle laying around. What really made a difference for me was cleaning the throttle body. But if you do it, there is a high possibility that you will need to have your throttle body recalibrated and this can only be done using a HDS tool, which the dealer and various mechanics should have. The throttle body relearn procedure itself will not solve this problem for you. Sorry for threadjacking but just a little information since you're deciding it is time to clean the inside of your engine.
Old Jul 27, 2016 | 04:49 PM
nfnsquared's Avatar
AAA: Not All Gasoline Created Equal | AAA NewsRoom
New testing from AAA has uncovered significant differences in the quality of gasoline sold at fuel retailers in the United States. The independent laboratory testing compared gasolines that meet TOP TIER™ standards often marketed to consumers as having enhanced, engine-cleaning detergent additives with gasoline brands that do not participate in the automaker-backed program. Among brands tested, non-TOP TIER gasolines caused 19 times more engine deposits than TOP TIER brands after just 4,000 miles of simulated driving.
Old Jul 27, 2016 | 08:27 PM
And just in case you dont use the hyperlink in NFN's post, here are retailers
Retailers
Old Jul 28, 2016 | 09:32 PM
Scottwax's Avatar
Mr. Detail
3.0 instead of a 3.2, but this was heading from Tucson to Phoenix, very slight downhill the whole way.
Benson, AZ to El Paso, TX, decent average speed.
Old Jul 28, 2016 | 11:19 PM
bakaryu18's Avatar
what state are you in now?
Old Jul 29, 2016 | 12:42 AM
Scottwax's Avatar
Mr. Detail
Live in Arlington, TX, grew up in Scottsdale, try to get back 1-2 times a year.
