For those who gone from TypeS Aspec lip to Base Aspec lip....
3 2 GONE
What did you do about the holes in the sides of the bumper that were drilled to secure the zap strap ends?
Front bumper
Front bumper
ATLS_666 (01-24-2014)
Dallas Chapter Leader (Midwest Region)
You cant go back once you drilled it lol You can either melt plastic into the hole front/back and sand it, prime and paint the entire bumper as a bumper repair. Not real difficult if you have the right tools. You have to melt the two plastics together. Or if you wanna be cheap and are not 100% picky... You could sand the inside of the bumper kinda rough, clean it, put a piece of tape on the outside of the painted surface and then fill the hole from the inside with epoxy and make a good sized 1" spread on the back. Let it dry and then take the tape off. Then use touch up paint and paint the epoxy circle. If you want it to look better wet sand and buff lightly... Just an idea worth a try if you wana be cheap
Your best bet would be to trade your bumper with someone with a base aspec lip. I'm sure you'll find someone.
ATLS_666 (01-25-2014)
benny_jdm
01-31-2016 06:15 AM
handsom-hustla
11-13-2015 05:04 PM
