Thermometer Limits?
Old Jun 10, 2008 | 11:26 AM
cristphoto's Avatar
Thermometer Limits?
Does the TL's outside temperature thermometer only go to 99 degrees? We're in a hot spell with temperatures over 100 and all I get is --- on the display. Is this normal?
Old Jun 10, 2008 | 11:30 AM
berite100's Avatar
mine wont go over 80... need to talk to a dealer.
Old Jun 10, 2008 | 11:49 AM
Will Y.'s Avatar
Registered but harmless
No- the outside thermometer should go higher, but "---" shows up when there is a problem. Mine once read 104*F, then "---" for a short time before stabilizing and dropping to 102, 101, etc. as the afternoon waned.
IIRC, there was a TSB for this issue (where the temp wouldn't read above 99*).
Old Jun 10, 2008 | 12:22 PM
Bearcat94's Avatar
AZ Community Team
I thought the temp display maxed out and showed "---" at 105* or 115*
(I can't get to an Owners Manual to check the max display temp).
Old Jun 10, 2008 | 02:04 PM
cbr04's Avatar
Team NBP
ours maxes out at 115. anything above that it displays "-----"
Old Jun 10, 2008 | 02:13 PM
clavodulce16's Avatar
[PA] NBP-TL
Mine was reeading 112 on saturday! i will check later today
Old Jun 10, 2008 | 02:18 PM
08WDP's Avatar
i have seen mine goes up over 100F before, but don't know or haven't see the max temp.
Old Jun 10, 2008 | 02:26 PM
TL2498's Avatar
Not just another newbie!
x2
Mine has never read higher than 115.
Old Jun 10, 2008 | 02:27 PM
erick3's Avatar
104 max here...but i believe the max is 120? i had mine replaced though under warranty b/c of the "---" readings...
Old Jun 10, 2008 | 03:50 PM
eds04TL's Avatar
Same thing happened 2 me yesterday... when I got into my car it waz reading 99 then it showed ---, then it read 103. That's my max so far...
Old Jun 10, 2008 | 04:02 PM
IntegraVT's Avatar
Stealthy A-CL Member
Mine displayed 104 at lunch today.
Old Jun 10, 2008 | 08:57 PM
lawwailok's Avatar
mine never read over 99F, anything above will read "---". so bring it back to dealership since it is still under warranty?
Old Jun 10, 2008 | 11:42 PM
MR1's Avatar
MR1
05/5AT/Navi/ABP/Quartz
If it gets too hot while sitting you get ---. I have seen 115+- on mine when it gets that hot outside here on a regular basis. It can only cool down a few degrees per mile so it will read correctly again over time if you keep driving.
Old Jun 11, 2008 | 07:19 AM
hoangtran9's Avatar
mine went up to 110 yesterday
Old Jun 11, 2008 | 07:26 AM
Oswald Vater's Avatar
My 04's maxed out at 115. Don't know if this changed with other MY's. I'm not sure about my 08 yet.
Old Jun 11, 2008 | 08:47 AM
RobxMcCarthy's Avatar
Mine was definitely at 104 yesterday... I was confused at first by the triple digits, actually skipped by it when cycling through the display options =P.
Old Jun 11, 2008 | 12:12 PM
SouthernBoy's Avatar
Registered Member
If it flatlines and continues to flatline, not returning to displaying a valid temperature, you need to fix this. Otherwise if your car sits for, say a week, expect your battery to be dead as a door nail.
It's an easy fix. Either remove the negative battery cable for about 3-5 seconds, or remove a fuse (not sure whether it's fuse 7 or 21 but do a search on "flatline" and you'll turn this info up).
This happened to me 7 weeks after I bought my '04 and some other members have seen this happen as well.
Old Jun 11, 2008 | 06:59 PM
Integra's Avatar
2007 Acura TL-S
lol wow crazy. the highest i seen on mine is like 70.
Old Jun 12, 2008 | 02:50 AM
A-TLvic882's Avatar
04 A-TL 6MT SSM/E N/Navi
Mine was reading 103 Last year.
Old Jun 12, 2008 | 07:13 AM
sunny201's Avatar
A J35A8 EG civic is in
Mine showed 108 on Saturday.. never seen it that high before
Old Jun 12, 2008 | 11:45 AM
wneichorn's Avatar
I need more money
111 is my max then its ---. How bad is it that this discussion is happening in June rather than July or August?
Old Jun 12, 2008 | 11:50 AM
Registered Member
I have seen mine hit 115. Over the past week, it has frequently hit 102 in several places around where I live. And I know it's accurate because back when it failed on me seven weeks after I bought the car, I calibrated it myself.
Old Jun 12, 2008 | 11:58 AM
DaveS221's Avatar
mine has hit 110 max, and 0 the lowest. It won't go past 0.
Old Jun 12, 2008 | 12:10 PM
xdaily's Avatar
Originally Posted by TL2498
x2
x3
Old Jun 12, 2008 | 12:18 PM
xdaily's Avatar
Originally Posted by xdaily
x3
Forgot to add my HFL bluetooth was going totally insane in this kinda heat.
Yes more insane then usual.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
08KBP_VA
Oct 22, 2019 01:55 PM
F-C
Motorsports News
33
Aug 22, 2018 09:53 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
