Is there an oiled foam air filter for the TL?
Old Jun 24, 2006 | 05:12 PM
jmichaelp's Avatar
I'd like to change out my oem filter, but am shying away from a K&N due to its propensity to allow larger particles through. Does anyone know if one is avaiable for our car? Thanks.
Old Jun 25, 2006 | 08:12 AM
SouthernBoy's Avatar
Registered Member
One what.. an oiled foam filter as in the thread title?
If this is what you are seeking, I highly recommend NOT to install a foam filter in your car's intake. Foam filters have a history of dislodging small pieces of their foam material and guess where it's headed when that happens?
K&N filter have two problems. First they're oiled and like any oiled filter, they can impart an oily residue in the intake stream and on the throttle plate. I said "can" with this statement. The second thing with a K&N filter is the fact that it filters better when it gets a bit dirty because the dirty gets trapped by the oil and acts like a filtering agent. K&N filters lose their flow characteristics rather quickly as they gather dirt.
The best after-market filter is the Apexi dry element "Power Intake" cone-shaped filter. You can fashion a fit for one of these for the Acura (I know.. I've done this with mine to test it), but frankly, none of the after-market units for our TLs are that much better than the stock intake which is acutally pretty decent.
BTW, the stock Honda/Acura OEM filter is a composite unit. It's oil wetted on the down side (facing the intake entrance) and dry element on the up side (facing the throttle body).
Old Jun 25, 2006 | 10:31 AM
Xpditor's Avatar
I didn't know that! Thanks. Now I know why we keep you around here. You're a font of useful data.
Old Jun 25, 2006 | 12:40 PM
Registered Member
Thanks. I got the information about foam filters from during a little research several years ago when I had my 2002 Altima SE. I found a test of four hi-performance filters and the foam and metal mesh came out on the bottom of the heap. Next up was the K&N and on the top was the Apexi. Also, Frankencar has dynoed their intakes and has found the Apexi has a 3.5 HP edge over the K&N for their applications. This is the most I've heard regarding the difference between them.
If you really like K&N filters, I see no reason not to install one as long as you don't live in a dusty area, you watch it closely and keep it sparingly with the oil, and you keep your intake stream (particularly your throttle plate) clean. K&N filter do flow well when clean and not over oiled (this is bad).
Purolator makes a decent air filter, but finding it is not easy.
Old Jun 25, 2006 | 08:09 PM
jmichaelp's Avatar
Yes, I know another thread - I certainly don't want anymore discussion wars to start up
I did read a bunch of other threads but don't recall much about oiled foam, mostly K&N. My experience w/ K&N on a Honda coupe was extremely positive - disappointed at first & almost forgotten about until I noticed a boost in 5th gear on the highway & also a jump in gas mileage (15-yr old car w/ years of historical mileage).
Anyway, thanks for the information SouthernBoy! I think I'll just stick with the oem filer.
bungln
Feb 20, 2019 08:47 PM
Sep 17, 2015 09:01 PM
HydrasunGQ
Sep 14, 2015 10:14 PM
Aleax
Sep 9, 2015 08:04 PM
bymotion
Aug 31, 2015 05:00 PM
