Synthetic transmission fluid?
Was thinking of putting Mobile-1 synthetic tranny fluid in my
08 TL (automatic). Any one think this is ok or not advised. The warrenty
is expired and the Acura dealer said the "acura genuine fluid" is a synthetic blend anyway so he did'nt see any problems. Just wanted to see what other
Acura owners thought.
If you do a search on Mobil 1 ATF, you find enough reading to keep you occupied for a while and reading about ATF in general might take you into retirement. ATF is a personal choice, so I'm certainly not going there again, but I will say that the Mobil 1 ATF is not recommended as a replacement for the Honda Z1 fluid, however, a recommendation by a manufacturer never stopped people on this site from using that fluid.
Unless there is somewhere on the site that I'm overlooking:
Mobil 1 Synthetic ATF has the following builder approvals:
Allison C4
It meets or exceeds the requirements of:
JASO 1-A
Ford Mercon V
Mobil 1 Synthetic ATF is recommended by ExxonMobil for use in applications requiring:
GM Dexron IIIH
GM Dexron IIIG
GM Dexron IIE
GM Dexron IID
GM Dexron II
GM Dexron
Ford Mercon
Voith H55.6335.3X
MAN 339 V1
Volvo 97340
Volvo 97341
Allison C4
JASO 1-A
Ford Mercon V
GM Dexron IIIH
GM Dexron IIIG
GM Dexron IIE
GM Dexron IID
GM Dexron II
GM Dexron
Ford Mercon
Voith H55.6335.3X
MAN 339 V1
Volvo 97340
Volvo 97341
Honda DW-1
Redline D4
Amsoil ATF
Mobil 1 ATF (double check that they still have compatibility with Honda transmissions as I've read somewhere that they may have dropped it)
Are synthetic and good replacements.
Redline D4
Amsoil ATF
SidhuSaaB
05-30-2020 12:40 AM
