Which synthetic oil?
I have an 06 TL that just hit 50,000 miles this week. After the first oil change I've always used Mobil One 5-20 weight oil. I've read (on Bob is the oil guy web site) that Mobil has had problems with meeting the API specs. Up till now I've always been loyal to Mobil One (I also always use their Mobil One oil filter) but am considering changing. I hear good things about Pennzoil Platinum oil. Are there any suggestions or concensus among TL users about which oil to use? I like to stick with one oil and not switch around. Thanks. Steve
AZ Community Team
Received 7,771 Likes
Get a free oil analysis kit from Blackstone Labs.
Try whichever Oil (the Mobil1, the Pennzoil, or both) and send the sample(s) back to Blackstone at your Oil Change Interval. See what the UOA tells you.
![](http://content.costco.com/Images/Content/Product/2091b.jpg)
search forum
Yep ![Smile](https://acurazine.com/forums/images/smilies/smile.gif)
Mobil 1 Extended, Royal Purple, Amsoil are the top 3 synthetic oils used on this forum...
Royal Purple is great, Mobile 1 Extended I'm running now, Amsoil I haven't tried. If you actually search the forum, you will see the reason and choice and why and why not.
i have been a long time user of mobil 1, that being said, last oil change i couldnt find the grade of mobil 1 i wanted so i went with castrol syntec...before that i used valvoline powersynthetic whatever it was called...i dont think it really matters when using one of the leading brand synthetics....pick one...i know ferrari uses penzoil platinum factory fill....give it a shot...
Head a da Family
I've been using Penzoil Platinum 5W-20 and a Bosch 3312 filter, the wider one. Both work fine for me.
http://pennzoil.com/products.html#Platinum
http://www.boschautoparts.com/Produc...PremOilFilters
Saw Royal Purple at Pep Boys last week, $8.95 a quart!
Sorry, but at that price, they can keep it.
I get the Penzoil at Walmart for $5.38 a quart or $19.95 for a 5 quart jug.
Im on the penzoil platinum too, seems to be working fine.
You dont need synthetic, it has its benefits but not mandatory
I wont run longer intervals on it, just feel safer pushing the car more,,,or driving in traffic
Then I like to believe the special molecules are splitting and reconnecting all the time, like the website commercials show
K&N filter is my choice, made same place as M1 filter
Amsoil synthetic straight 30wt in a warm climate like mine.
Redline makes an extremely good 5w-20 with a very high (for a 20) HTHS value.
I know I say this every time but if any of you looked at actual results from people who run their car hard on the thinner RP stuff, you would drain it out of your engine immediately. All I can say is advertising at it's best (or worst).
The HT/HS is below the minimum acceptable level for most manufacturers.
While not all Mobil One is true synthetic, I would run it before RP any day.
Most Mobil One oils are a mix of III and IV. A couple are IV or IV and V.
Some Mobil One products are awesome. Their 5w-40 is one of them. If I weren't already content with the Amsoil I'm running, I would be running the 5w-40.
AZ Community Team
Not sure it it is true for the niche brands (RP, Red Line, Amsoil, etc).
SSM Sport Shifting
Most of the botique brands, Amsoil and Schaeffers for sure, clearly label their group III oils as non-synthetic dino oil. Not sure if Redline and Royal Purple make a non group IV or V oil.
SSM Sport Shifting
As far as extended drain intervals I would still try to change every
3000-4000 miles no matter what kinda of oil Im using. I go by the
color and thickness of the oil to determine when it needs to be changed
anyway.
I'm just not sold on the fact that synthetic oil is a benefit to use.
Just my
Someone prove me wrong with some good info.
For anyone interested, this is why I put a lot of weight into the HTHS rating of an oil.
"Three Exxon Researchers found that a minimum HTHS of about 2.8 mPA.s was the MINIMUM HTHS viscosity needed for normal wear, with the higher the HTHS being better for minimum wear. IN general, the higher the viscosity, the greater the HTHS.
For example, in a fleet of taxicabs using a GM 4.3L V6 engine, if the HTHS was 2.35, the startup film was 0.097um and 2.56 um at running; if the HTHS was 2.98, cP, the Startup oil film thickness was 1.231 um while the running film thickness was 3.22 um.
In Dynomometer wear tests using four GM 3.8L engines, the wear mass of a connecting rod bearing was as follows:
HTHS 2.1
mass loss (gm.) - 190
HTHS 3.2
mass loss (gm.) - 28
For "mains" bearings:
HTHS 2.1
mass loss (gm.) - 150
HTHS 3.2
mass loss (gm.) - 40
A jump in HTHS by about +1.5 results in approximately 1/5 the wear. Now this relationship is not linear and flattens as one nears a 40+ weight oil.
I should also mention that this test showed little differences in wear between a high quality 5W20 and a 10W30 for oils of close HTHS. For example, The average wear of one of the 3.8L V6's showed a total wear of the Connecting Rod bearings as 48.4 grams for the 5W20 verses 44.3 grams for the 10W30. For a 10W40 oil, the wear was 39 grams!!!"
This test involves weighing the bearings, installing them in an engine, running the engine, removing the bearings, and re-weighing them to see how much weight they lost due to wear. Forget any other tests you have seen such as the wear ball test and all that crap. This is a real life test.
HTHS may be more important than viscosity. This is why I like Redline 5W20. You get the flow of a 20wt and the HTHS of a good 30wt.
The Amsoil I'm running has an HTHS of 3.6 which is signifigantly higher than what came in the car yet it's not that much thicker at operating temperature. It's truly a win-win situation.
HTHS 2.1
HTHS 3.2
HTHS 2.1
HTHS 3.2
It may help with extreme weather conditions I will give you that sir.
anyway.
Just my
Someone prove me wrong with some good info.![Wish](https://acurazine.com/forums/images/smilies/wish.gif)
anyway.
Just my
Generally a synthetic base oil has a naturally high viscosity index. This means it won't require as much viscosity index improver (VII) to get the multi-grade designation. VIIs are known to cause sludge and break down under high temps and high stress.
The oil I run is a straight 30wt since it contains no VIIs yet also qualifies as a 10w-30 due to it's natrual high viscosity index. I get all of the benefits of a straight weight and the benefits of a multi weight.
On the extreme end of things, a synthetic will always flow better when cold, much better.
With extreme heat, it won't break down as easily, won't coke as easy in turbo bearings, generally has a much higher flash point, and resists permanent shear.
It's not something you need but it's a nice insurance policy.
For what it's worth, I run a regular dino 20-50 oil in my 600hp turbo car with a 1,000 mile change interval. My oil temps run very low and unless I take it to the track, I'm never on the throttle for more than a second or two.
Being an Acha Bacha in
Just google Amsoil and the rest and the facts speak for themselves.
Group-III is made by hydro cracking dino oil. Both start as dino oil. Only difference is Group-IV starts from a gas (unlike Group IIII) so it has less contaminants. (Think distilled water vs reverse-osmosis filtered water)
Sure a Group-IV is better in regards to having less contaminants, but that doesn't make Group-III oil a bad oil. Reverse-Osmosis filtered water is still very pure, and better then drinking water out of the pond.
And for the record, Amsoil is not the only "synthetic" with regards to being a Group-IV. German Castrol is also a Group-IV synthetic.
the govt changed the standards and allowable materials to be added to oil:
result was a change in some brands-example Mobil1 went to blended base formula BUT was able to keep the same name
Old school good Mobil1, is now Mobil1 High Mileage
I dont care if its pure synthetic base or whatever- as long as it protects the engine, and sprectrograph analysis is the only true judge of that.
Color and viscosity are lousy indicators. Dirty oil is working well!
Kendall oil is castrol gtx--same company
Some years ago they were advertising kendall for racers and castrol to street cars
In a cost saving move they dropped kendall ads and sell GTX as `racers oil for the street`!
Thats why the tv ads with simulated dyno wheels and racing type demo of the oils protection.
You can still find kendall, and its good oil but its not new or different
Actually, it is NOT correct. Mobile 1 IS synthetic. Group-III synthetics are still legally synthetics... Why do you consider Group-IV the only synthetic? Because PAO is not dino oil? You do realize that Group-IV is ALSO dino based... The PAO base stock is made from Xylene gas, which is made by thermal cracking dino oil.
And of course there are plenty "real" synthetics like most Amsoil, some Mobil One, Royal Purple, Redline, Schaeffers, etc.
I find it funny that the high end manufacturers label their grpIII oils as dino oil while their IV and V is labeled full synthetic. Then you have Mobil and plenty others calling their group III "full synthetic". While it's legally correct, it's misleading to the consumer.
SSM Sport Shifting
I also change mine every 4,500 even though it's a premium synthetic that's rated to go 25,000. Even if the oil is good, there is still the contaminate load in the oil.
Great stuff man. Is there a brand that you use in your TL that
I could research about?
A oil debate is fruitless.
Change your oil on the interval normally recommended in your manual and you will be fine with any good high quality oil; it doesn't matter.
99% of the people here will not keep there car long enough for oil to be a factor if its changed when its suppose to. I use the meter on the car for my changes. I will drive a little longer if I've been on long road freeway trips.
For the OCD people like me who plan on keeping it half a million miles, there's Amsoil lol.
I highly suggest Redline 5w-20 for any climate. It has no VIIs so you could call it a straight 20wt. It has a very high (for a 20wt) HTHS so you know it will hold up well under high load/high temperature conditions. It's a 20wt obviously so no worries about cold flow. With the thin 20wt and high HTHS value, it's like having your cake and eating it too.
There's Amsoil's ACD that I run. It has a good HTHS of 3.6. It's a straight 30wt (no VIIs) but qualifies as a 10w-30. I run it because it rarely gets below freezing here and summers are 105+ so a 10w-30 fits the bill nicely.
What sets it apart from most oils is a high ZDDP and high TBN (total base number) level. ZDDP is probably the most effective and widely used anti-wear additive. It is especially beneficial in the valvetrain at the cam to lifter contact.
Any newer SM rated oil (pretty much anything on the shelves) has a mandated lower ZDDP level. ZDDP in high doses *might* be bad for the catalytic convertors. When they upped the federally mandated emissions warranty to 80,000 miles, they changed the allowable ZDDP level in oil. The thing is, unless your car burns oil, there's no way ZDDP can hurt anything. Anything short of visible smoke is not going to cause problems. Mine just turned 70,000 and I've been using the same oil for over 50,000 of those miles with no issues.
Hope this helps.
SSM Sport Shifting
My prev car (honda) had 180,000+ when I sold it & its still running
strong. I'm just interested in whatever I can do to prolong
the life of my TL.
There is 2 types of oil, one is PURIFIED OIL that is marketed as being SYNTHETIC which tricks the consumers.
And there is the other that is genuinely synthetic and the only one to my knowledge that fits in this category is AMSOIL and you might be right with the other one you mentioned being in this category as well. I encourage everyone to just google this and the facts are clear as night and day. They did a test with amsoil and mobil 1 so called synthetic and.. the results showed that amsoil (true synthetic) much better than mobil 1 (so called synthetic).
Here's just 2 of the many examples that is available to prove why amosoil is better:
![](http://www.enhancedsyntheticoil.com/astm_d4172_400px.gif)
This is showing the protection on a 4 bear wear test. Basically 3 balls put together lubricated with the oil and then a 4th ball placed on top and forced to rotate on it, and the friction and scarring due to it is being measured. Obviously the lower the friction, the lower the scarring and the better the protection from the oil.
![](http://www.enhancedsyntheticoil.com/astm_d5293_400px.gif)
This one is showing which oil operates best on frigid temps and cold engines and gives the best protection. Lower the viscosity the better the protection in cold start and protection. Its much easier spraying something like water out then maple syrup.
There is much more info, just search.. and look I didn't have to use fancy terms to explain any of this.
