Synchro's not synching!
Old Jan 3, 2005 | 10:14 AM
I now have about 1200 miles and my 6MT/A-spec/Navi is great.
However, I pulled out of Lowe's and thought I was in First. However, I stepped on the gas and got very little. No RPM rev, no stall as I let out the clutch but I moved forward at about 2 miles per hour even though I stomped on the gas? I put the clutch in and then went to neutral and back to first and then went forward as usual. No grinding. It felt as though I wasn't yet in gear but I wasn't in the neutral gate either. The only thing I could figure is I had engaged the synchro but not fully the gear?
I immediately noticed a burning smell in the car. I only went about 10-20 feet like this (my nose was out in the lane but luckily no one was coming). I opened the windows and this cleared.
I've noticed this a few times - while I'm stopped at a light I'll put in the clutch, attempt to place it in first and feel as though its not quite in first but in some in-between stage. I then go back to neutral and then back to first before I add gas, let out the clutch and pull out.
This happened about 300 miles ago and I haven't had a problem since.
Any thoughts? I read the double clutching post with link that mentioned that you, while stopped at a light, should put it in 2nd with the clutch all the way in before you put it in first and this will engage the synchros properly?
Thoughts?
Old Jan 3, 2005 | 10:25 AM
cM3go's Avatar
I do that sometimes, shift to 2nd and back to 1st before releasing the clutch pedal, although unnecessary, it "seems" to help
Old Jan 3, 2005 | 10:43 AM
Thoughts?
Old Jan 3, 2005 | 10:51 AM
don't know why this posted twice. Can mods delete one of them. Sorry. Thanks
Old Jan 3, 2005 | 12:27 PM
Road Rage's Avatar
Not a Blowhole
I think Honda's MTF stinks - see my post on alternatives.
Engaging 2nd before clutching and engaging 1st works by slowing down the spinning synchros.
Old Jan 3, 2005 | 01:11 PM
Bluenote's Avatar
Ex-Acura Service Manager
Sounds to me like you may have accidentally engaged 3rd gear & were slipping the clutch.
Old Jan 3, 2005 | 01:31 PM
Yeah, the 'in Third' idea crossed my mind also and may very well be what I did, since I was talking to several people in the car about all the great features. That might just have been it. Haven't had a problem since and really love the car.
G2Teg2TL
Apr 1, 2008 09:02 PM
6spdtls
Feb 14, 2008 01:39 AM
wonton
Jan 9, 2008 12:33 PM
virtualbong
Technology
22
Oct 14, 2007 01:23 AM
EPS CL
Oct 31, 2005 08:45 PM
