Sylvania "LEDriving"
So I got bored today on break from work and I went to a nearby Autozone and purchased Sylvania "LEDriving" bulbs for my license plate... I am blown away by them, see for yourself. I also purchased a set of the SilverStar reverse lights - I'm also impressed by those too.
https://acurazine.com/forums/3g-tl-2004-2008-93/review-sylvania-osram-ledriving-lights-875464/
I just installed these a few days ago and I'm pretty sure they are brighter and whiter than those LEDriving bulbs. Not to mention a little cheaper.
http://www.vleds.com/bulb/194-168-15...58-1-pair.html
alexb92 (02-24-2013)
The Sylvania plate bulbs are very nice and so far the closest thing to OEM LED plate lighting that I have seen. To vietxquangstah above, not sure why so many people on this forum think that brighter is better. Not only does a bulb thats too bright just not look good, but it doesnt look anywhere near OEM. For example, when im looking for a LED license plate bulb I want one that closest represents the output and color of an OEM plate light on a new BMW, or Lexus, or something like that. Not a hideously bright bulb.
So I also have the Sylvania LED bulbs in my plates and they are the best I have seen so far. They are a tad on the bright side, but I toned them down slight with a small piee of electrical tape on the end of the lens and IMO they are now perfect.
The following 2 users liked this post by JTS97Z28:
alexb92 (02-24-2013),
Healingduck (02-25-2013)
Received 6,470 Likes
Very nice, Alex. They look so clean (the light does).
I've got bulbs in mine too. I didn't want ultra bright-just a cleaner look.
Front doors - 2
Front domes - 2
Rear domes - 2
Inside of trunk - 1
Front mirrors - 2
So you're about to spend $90+tax on some LEDriving lights for interior/doors/trunk
For less than $30 shipped (no tax) you can get some LED board panels for your interior and it will be a little brighter than the LEDriving sylvania bulbs and cost only $2.70 each!
http://www.ebay.com/itm/120968360370
I actually have the 12 LED board versions for doors and domes and they are insanely bright. I would suggest using 6 LED boards and it will be perfect. 5K pure white, no hint or tinge of blue at all.
I have those 6 LED boards for my front mirrors and it's brighter than my 5 LED bulb I had in it before.
If you want pictures check out my thread right here https://acurazine.com/forums/showthr...3#post14293223
Remember, those pictures are with 12 LED boards. 6 LED boards would be half the brightness which I think would be just right.
Front domes - 2
Rear domes - 2
Inside of trunk - 1
Front mirrors - 2
Front doors - 2
Front domes - 2
Rear domes - 2
Inside of trunk - 1
Front mirrors - 2
Front domes - 2
Rear domes - 2
Inside of trunk - 1
Front mirrors - 2
Do the plastic covers over the lights simply pop off? What's the safest method for removing them?
Are you talking about the plastic on the domes? You can pop those off with a small screw driver. There are rectangular wedge areas to wedge it in safely. Hard to see at first but put a flash light near it. I used a small clothe on the screw driver so I didn't scratch the panel or trim.
Thanks everyone for the help!
92legend
07-08-2001 08:41 AM
