Switchback question
Old Sep 1, 2013 | 10:41 PM
j_u's Avatar
j_u
Switchback question
i want to purchase some switchbacks from vled and i was wondering would i need to ordered the base adapters as well? if someone can help me out it would be great
Old Sep 1, 2013 | 11:32 PM
story.customz's Avatar
Just order the bulbs and do the relay resistor mod to prevent hyper flash
Old Sep 1, 2013 | 11:58 PM
j_u's Avatar
j_u
Alright cool
Old Sep 2, 2013 | 06:22 AM
JTS97Z28's Avatar
I don't recommend doing that. Some people have experienced really messed up electrical issues. Not only that but that relay is a bitch to get out without breaking tabs, and if you ever want to reverse it you have to buy a new relay. Why not just do the easy plug and play way and use vleds system? Not only that but if the OP is looking at the V3 Triton switchbacks, they have a built in equalizer.
I'm not even sure if that's the OP's question anyway though. He talks about adapters. If your looking at the V3's you simply select whichever bulb base your replacing and the kit will come with the correct adapter for your application.
I highly recommend only going with the V3's. Everything else pretty much sucks in comparison. Spend a little extra and do it right the first time. I think they have 20% off promotion that's good through today!!
Old Sep 2, 2013 | 09:50 AM
j_u's Avatar
j_u
^ i decided to go with the v3 even thou i didnt want to spend that much but i noticed they were having a promotion for labor day so i took advantage of it
Old Sep 2, 2013 | 10:18 AM
Yeah that's what scares me about doing mine. I have hyper flash but I don't mind it. Rather have super quick blinking then risk the chance of electrical problems. Just thought I'd tell Op there's an option to get rid of it
Old Sep 2, 2013 | 10:19 AM
JTS97Z28's Avatar
You will be happy you went with those, trust me!!
Old Sep 16, 2013 | 09:52 PM
j_u's Avatar
j_u
i need help with my v3 installation. if someone can shine in with some info it will be great. the connection with the fuse in it from the controller box is suppose to connect to the socket from the turn signals correct because mine doesnt fit it. its the 7443 bulb type.
Old Sep 16, 2013 | 11:21 PM
wilztlxs's Avatar
TLX-S
the entire bulb assembly you removed from the connector, pull the bulb out and plug it back in to the connector, the base from the V3 plugs in place of the bulb
Old Sep 17, 2013 | 12:49 AM
AZP-TL's Avatar
You'll only have electrical problems if you do a bad solder job and it's very reversible as long as you keep the shunt. Since the V3s have resistance built in yeah, might as well make use of it.
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
DerrickW
Nov 15, 2015 05:52 PM
navtool.com
Sep 25, 2015 05:15 PM
