Sunroof
Keep Right Except to Pass
Press the sunroof switch vertically (that is, instead of sliding it one way or the other, put your finger on it and push like a button). Make sure the moonroof shade is open first.
The following 3 users liked this post by 1995hoo:
BENTFAM (08-29-2011)
The following 2 users liked this post by Trunk Monkey:
BENTFAM (08-29-2011),
justnspace (08-29-2011)
The following 2 users liked this post by lights:
i don't know what's wrong with my sunroof button but my "1 touch open/close" and my "sunroof tilt" feature doesn't work.
it opens and closes just fine, i just have to manually hold the button down for the whole duration.
when i press the button up to tilt the button makes a clicking noise so i know i'm doing it correctly, but the sunroof doesnt move.
and when i try to use my 1 touch open/close feature by pulling the sunroof button all the way back til it clicks and let go, my sunroof just stops as soon as i let it go.
Registered 3.5L Member
Dont feel bad posting this question...I had my car for 7 months before I figured it out
My '02 was easier to understand initially...
It seems he knows how to do it but still can't. If I were you, I would check all the fuses to see if there is one blown. Then reset the ECU? after that going to have to check that motor out if the previous options don't work.
takin care of Business in
Received 4,732 Likes
op....
Tilt up: Push the button UP
Slide it open: Push the button back
Slide it open 1 touch: Push the button back till you hear a little click
Slide it close: Push the button forward
Slide it close 1 touch: Push the button forward till you hear a little click
Now you can do combination....you can go from tilting to completely opening the roof with 1 touch as well...or go from completely slid open roof to tilting with 1 touch as well....
mlody
12-04-2019 02:11 PM
