Summer MPG challenge
Old 07-18-2011 | 11:26 PM
  #41
Hi speed's Avatar
runnin a little boost
Originally Posted by swoosh
so RDX injectors mess up your trip computer eh....MPG and range for instance ?
Reason I ask is coz I was going to install them in my car....pending some AFR readings I get....also how much is the stock and RDX injectors capacities (i thought the RDX were 440cc) correct me if am wrong....
I am pretty sure the RDX injectors are 410 cc, stock I think is 210 cc
swoosh (07-18-2011)
Old 07-18-2011 | 11:34 PM
  #42
swoosh's Avatar
takin care of Business in
sweeeeeet....thanks dude....now back to the summer challenge
Old 07-18-2011 | 11:42 PM
  #43
pjillta's Avatar
UA6 NPB!!!!
is this highway only or a mixture of just in general 1 hour of driving?
Old 07-18-2011 | 11:43 PM
  #44
9632tl's Avatar
Radical Member
Originally Posted by Hi speed
Beat this
The only explanation I have is that you tow your TL behind an Rv ;D
Old 07-18-2011 | 11:47 PM
  #45
Klexicon's Avatar
Man, the best I've been getting is around 25. I did almost get 450 miles to the tank when driving from Lubbock to Houston on the freeway. I think that's the best I can do. My girlfriends Audi A3 is getting around 30. So jealous.
Old 07-18-2011 | 11:55 PM
  #46
paperboy42190's Avatar
or....he has rdx injectors as he stated above
Old 07-19-2011 | 12:18 AM
  #47
Fatfrii's Avatar
wow....i iam clueless on the RDX injectors i didnt know people put them in TLs nor do i know why....time to abuse the search engine instead of this thread.....ur welcome
Old 07-19-2011 | 12:02 PM
  #48
swoosh's Avatar
more air + more gas = more power
so if you keep putting more air but same amount of gas you are running lean....so upgraded fuel injectors will give you some more fuel and hence more power....
Old 07-19-2011 | 12:56 PM
  #49
I hate cars's Avatar
RDX injectors ( almost double stock flow). The Mid looks at duty cycle of injectors and they are not being used to their full potential most of the time.
That makes sense. So it calculates based on DC and stock flow rates. The DC is around half as much with the large injectors so the ECU thinks you're using half the fuel. Makes sense now.
Old 07-19-2011 | 12:59 PM
  #50
More air and fuel = more power. Remeber, the ratio is constant so you need more air to match the extra fuel. The turbo does a nice job of supplying the additional air so you need injectors that are at least twice as big. On a stock TL, adding these injectors would do nothing for power since you would not have the air to take advantage of the extra fuel. The ECU would just pull the DC down on the injectors and you would be back to where you were with stock injectors.
Old 07-19-2011 | 01:12 PM
  #51
RaviNJCLs's Avatar
I got >50 once for about 2 miles and then right back to 32.
Old 07-19-2011 | 01:19 PM
  #52
swoosh's Avatar
been there done that LOL
Old 07-19-2011 | 02:18 PM
  #53
geekybiker's Avatar
Originally Posted by I hate cars
Pushing the pedal opens and closes a butterfly valve that restricts airflow. That's the only way a gasoline engine is throttled, by restricting airflow. All that matters is how much air the engine is injesting, not how far open the throttle valve is or how far you're pushing the throttle.
The air fuel ratio remains constant so more air= more fuel, less air=less fuel. Whether the restriction comes from the filter or from the throttlebody doesn't matter.
That's not exactly true. Tuning stand alone ECU's I had settings based on throttle position. Generally that only mattered at high throttle positions once you get out of close loop mode though. Just cruising around, yah all it cares about is how much air its getting, not what the restriction is.
Old 07-19-2011 | 05:29 PM
  #54
If you're talking about a speed density, the restriction posed by the filter at high throttle openings shows up as more vacuum on the MAP sensor and all is fine. If the ECU ignores the MAP and 02 at full throttle it can go rich from a restriction. If PE is triggered by throttle position AND it goes into open loop AND it's a MAF equipped car that pegs the meter, it can go rich.
The TL seems to stay in closed loop all the time from what I've seen.
Old 07-19-2011 | 06:05 PM
  #55
geekybiker's Avatar
Well, my particular system was MAP on a link ecu. It would enrich based on throttle in open loop, and on throttle application. That's not ignoring the MAP, but purposefully enriching it. Can't say in detail what the TL's ecu does. I wouldn't be shocked to see on throttle enrichment or other small tweaks.
Just saying that sometime throttle position is used on some EFI cars. Its not sensor data that is completely thrown away.
Old 07-19-2011 | 07:21 PM
  #56
I agree. It's used for throttle tip-in enrichment which does the same thing as the accelerator pump does in a carburetor. It momentarily enriches the mixture the second you hit the throttle, before the MAP or MAF can react to the airflow increase/pressure drop to avoid tip-in stumble.
Tip-in is still used but absolute throttle position has very little weight put on it for calculating mixture. It does have a hand in determining the target AF in some cases.
Old 07-19-2011 | 07:53 PM
  #57
Ruby's Avatar
US Navy Seabees
I consistantly get 23 mpg average. Pure highway cruise control: 28 or 29 factors depending.
Old 07-19-2011 | 07:58 PM
  #58
twinspool's Avatar
I get terrible gas mileage. I filled up and drove 162 miles roundtrip with ac on and closed windows and was down to half a tank.
i know that isnt good..
Jae
Old 07-19-2011 | 08:10 PM
  #59
RaviNJCLs's Avatar
Jae
Have you actually measured it? I recommend a complete fill up (do not top off), drive it until it is 75-80% gone and then fill up again. Do the Math. Repeat process.
Old 07-20-2011 | 09:10 AM
  #60
JTK21351's Avatar
My MID currently has about 11 and a half hours of driving on it, with an average speed of 35mph and an average of 26mpg. I think I'm doing pretty well with the mileage for having a lower average speed.
Old 07-20-2011 | 09:31 AM
  #61
1995hoo's Avatar
Keep Right Except to Pass
July 2 when we were driving from the Jacksonville area back home. I reset the MID after we stopped for gas in Walterboro, SC. Took this picture when we stopped for dinner at an Arby's in Emporia, VA, at around 9:00 that night. Cruise control was at 75 for most of the trip, although I was doing around 81 several times when there was enough traffic to allow a faster speed without standing out. Ms1995hoo wanted me to stop for gas at the same time and I refused because I felt we hadn't gone far enough, so we ultimately stopped about 51 miles later off I-295 in Virginia. Car probably could have gone further but we were coming up on a stretch where there were fewer exits and not many gas stations.
Old 07-20-2011 | 10:56 PM
  #62
Hondaforlife954's Avatar
www.colradodetail.com
This is from awhile ago......
Old 07-21-2011 | 11:24 AM
  #63
swoosh's Avatar
^^^ that is actually amazing gas mileage for the speed....
unless you did a 1500 mile trip averaging 55mph and 35mpg and in the last 300 odd miles in traffic and hence your mph went down to 47 and mpg to 29...
Old 07-21-2011 | 12:51 PM
  #64
mdrolet77's Avatar
air filter wont change a thing unless its so clogged up that theres not enough air to burn all the fuel, which would mean your filter is near completely blocked off at highway speeds...
Old 07-21-2011 | 03:55 PM
  #65
twinspool's Avatar
I am getting 16mpg per the trip computer. Just recently installed a K&N drop in filter since the last one was filthy. I just checked the NAVi and I have a code for P0174 and a P0159 but no check engine light. I am thinking this is due to what I have read being a necessary ecu flash update but it definitely is hurting my mpg..
thoughts?
Old 07-21-2011 | 05:11 PM
  #66
when i did this i was just seeing what it gets in general. I reset it after i did spark plugs and airfilter, then just started driving. So it includes alot of highway, i would say 70-30. But yes amazing mpg....funny thing is my motorcycle gets the same only bc its modded and very fast!
Old 07-21-2011 | 05:14 PM
  #67
thoughts?
Check these out might help.....
http://www.obd-codes.com/p0159
http://repairpal.com/OBD-II-Code-P0171-and-P0174
Old 07-21-2011 | 05:33 PM
  #68
r3devi7's Avatar
ReDevil
I have been getting consistent 32-33mpg, but I do a lot of back woods road driving, and drive like an old lady
Old 07-21-2011 | 05:36 PM
  #69
is that on the tack or at the pump? When calculated i get 27.4-28.9 actual.... when i had it say 33mpg filled up and was only 29.3ish....
Old 07-21-2011 | 07:22 PM
  #70
r3devi7's Avatar
ReDevil
Thats from the MID, I know its pretty close though as I did figure out the first few tanks manually, I was getting 23-25mpg, and thats what the MID as telling me. Its hard to keep your foot out of it with a new car lol.
Old 07-24-2011 | 05:19 PM
  #71
Gryphen's Avatar
Wallet raped by my
1 week of driving for my job. Its about 70-highway/30-city driving.
Old 07-24-2011 | 05:38 PM
  #72
erdoc48's Avatar
06 Anthracite TL
My max would be 34 mpg at a steady 65 mph NJ to SC (I don't have pics of it but have done it on several occasions). RPM's < 2K the whole way. On a regular basis, 27 mpg mixed (70 hwy/30 city) driving and of course, worse in the winter (~ 23 mpg).
Old 07-24-2011 | 05:45 PM
  #73
TLdream's Avatar
I dont know anyone who had the stocks measured, but i would bet on them beaing atleast 245cc (thats what most other honda injectors are). They might even be as high as 290's.
Old 07-25-2011 | 03:06 PM
  #74
SmileyOr's Avatar
I've driven from Portland, Oregon to Seaside, Oregon over the coast range (1,600' elevation) with the cruise control set to 57 mph. I didn't have to adjust my speed for the entire highway section of the trip. I pulled into the parking lot of the motel and the display read 30 mpg with an average speed of 54 mph IIRC.
07' Type S
Old 07-27-2011 | 12:45 AM
  #75
ATLTL33's Avatar
Originally Posted by robertran88
i have an 07 TL-S im bairly getting 300 on a full tank, anyone else got this problem?? this is horrible that's average of 21 mpg's :/
I get about 220-255 on a full tank in my 07 S, but its mostly city driving
  #76
ATLTL33's Avatar
^^^and cold air intake
Old 07-27-2011 | 02:50 PM
  #77
javamanbill's Avatar
J Bill
I took a recent trip to Red River, NM from Tulsa, OK and was amazed at the mileage I was seeing. I had never been able to get the 30 MPG highway as our manufacturer suggested. Turns out I was always driving too fast. I tend to drive 80 or so on the highway. This trip I drove 70 on cruise control. The below picture is my reading from Cimmarron, NM to Enid, OK. Again, cruise on 70 (average is lower due to slowing down as passing through small towns or construction) and Mid reset at the gas station...not when already at highway speed. Tires at 40 PSI and car pretty loaded up with camping gear so might have been better with less weight. At the two hour mark I was at 37 MPG!
In Enid OK, prior to filling up with gas for last leg of trip:
Two hour point of trip:
Old 07-27-2011 | 02:52 PM
  #78
swoosh's Avatar
i have never been able to get 36+...awesome
RobbDizzle
10-15-2015 11:16 AM
lanechanger
10-13-2015 10:56 AM
marinrain
ILX
10-06-2015 12:36 AM
Froid
09-27-2015 06:16 PM
ceb
ILX
09-27-2015 10:56 AM
Quick Reply: Summer MPG challenge
