Suggestions/Help
Old Dec 23, 2008 | 08:41 AM
Starchyld's Avatar
Suggestions/Help
Ok, so I bought my 06 TL in October, right now the car has 69,000km on it. When I purchased it, the only thing that was done to the car was, new brake pads, rotors & tires. I have about 20% oil life left in it (took some long drives). I was planning on servicing (doing oil changes, changing spark plugs, brakes etc. myself when the time is needed) in my garage. I'm on Christmas Holidays for a while and I wanted to tune up the car a bit, change the air filter, oil change before January etc. I'm a totally newbie when it comes to performance parts on cars, I'm more into the looks and accessories. Like I mention the car has 69,000km on it, is there anything else I should look for to change, or do while I'm at it? From the service records, it just had simple services done, no major stuff I'm guessing...Any help/suggestions on how to spend some money on the car in the performance/tune up area would be appreciated!
Old Dec 24, 2008 | 06:47 AM
LoveMyTL-S's Avatar
Here is the 06 TL manual:
https://techinfo.honda.com/rjanisis/...606O00208A.pdf
Under maintenance for your cars mileage, approx 43,000 miles, I'd also make sure the air filter and pollen filter are both changed. Check all your fluilds, oil, transmission, brakes, power steering, radiator overflow, etc. Also tire pressure. Other than that, I think your good. Welcome to AZ
Old Dec 24, 2008 | 09:30 AM
ggesq's Avatar
change your tranny fluid 3x3 method (assuming your TL is an AT).
VivienL
May 1, 2015 08:34 AM
rhino-31
Dec 20, 2010 06:14 PM
blazinginder
Nov 1, 2008 10:39 AM
xway23
Mar 20, 2007 11:41 AM
