Sub in Rear Deck Question
Old Jun 27, 2004 | 12:53 PM
Hey im an audio noobie. I was thinking about replacing the sub in my deck and was wondering if I got 1 infinity 10" kappa perfect sub, would it fit in the read deck? I dont want an enclosures in my trunk or anything and would prefer for everything to look stock. Im also thinking about replacing the speakers w/ all infinity kappa perfect speakers and was wondering about the center channel? what kind of speaker is it? Its an odd shape and I would have to open the dash to look but can anybody just tell me off hand?? Thanks!
Old Jun 27, 2004 | 01:15 PM
GunnmeTaLCURA04's Avatar
GÜNnµ ¡Ï
Same thing here... can someone help? And also.. i see myself having to put the volume level at 30 everytime to listen to it, and even hard at times when on the road with windows open.. I feel my dadss 1997 Escort is louder. will the changing of speakers do it good? And watt size is the stock sub? I am asume putting a new one, will demand more power.... does our system provide this power?
Old Jun 27, 2004 | 01:51 PM
stock sub is 8"
Old Jun 27, 2004 | 05:11 PM
Road Rage's Avatar
Not a Blowhole
I am an EE. And no bass addict - I keep the sub level at +2 or lower to avoid groos distortion and bass boom. To help answer your question, I would need to know:
1) The sensitivity of your proposed replacement speaker (SPL 1w/1meter in dB)
2) The nominal impedance of the existing woofer.
3) The nominal impedance of the replacement woofer.
4) The low-pass crossover frequency of the sub to mid drivers in Hz.
If the sensitivities of the OE vs. replacement are very different, you may not be able to get adequate output. Also, if the replacement has a low nominal impedance, you run the risk of overheating the bass amp due to excessive current. One would also need to know the low-pass, as the frequency may be higher than the replacement's frequency response, which would leave you with a glaring hole in the lower midrange.
I have the equipment to do these measurements, but I doubt many audio shops do. Point is, you may end up with bass out the wazoo, but you may muck up the linearity of the frequency response, which would change the carefull tuned stock system. IMHO, that would be a bad tradeoff.
Old Jun 27, 2004 | 06:32 PM
GÜNnµ ¡Ï
tooo much stuff. i think i will keep it as is....
KB1_EJ6
Nov 13, 2016 09:51 PM
Dunnik
Sep 15, 2015 11:52 PM
d.lim
Sep 15, 2015 08:54 PM
datadr
Sep 12, 2015 09:12 PM
