Stupid transmission question
Just recently had my trans. Rebuilt at 150,000 in an 06 TL, I don't think they put dw-1 back in it as its more of a grey tint than red. Anyway have been waiting on the 10,000 Mark so I can do a 3 quart swap and every 10,000 after till I know what's in it. But, question is, why does it matter or does it if the trans. Was rebuilt with an after market kit? I'm sure it's not Honda parts, it wasn't a crate trans. From Honda so does it really matter what's in it being not o.e.m. anymore?
Although parts in this rebuild may be aftermarket, the critical load bearing components would most likely be identical in material and dimensions to the Honda/OEM equivalent (or so we hope ). That being said, the recommended OEM transmission fluid should still be best suited for the job. The biggest influence on lubricating oil for tranny should be material, material interface/tolerance, and temperature. Since DW-1 has superseded Z-1 in Honda auto's, I would suggest that DW-1 is going to suit your rebuild very well.
PS. I am by no means an expert on aftermarket/rebuilt tranny's. Just giving you what my thought process would be, were I in your shoes.
^^^this.
qwxilvr
5G TLX Problems & Fixes
05-07-2016 02:35 AM
