Is it stupid to go to dealer for this?
Got in my Car the other night and noticed driver heated seat was not illuminated. The orange lights worked just not the blue. Looks cheap at night and I'm aggravated with it.. I have one of the Best Warranties ( so they say ) and don't see why it wouldn't be covered. I made an appointment for tomorrow morning I'm meeting with a new service guy since the one i use to deal with quit. Hopefully he's not a D*ck and will do it.
Saw the DIYS and it looks like a pain to rip the car apart for a light bulb..
Also was going to mention to him about the fact that when Im driving and have radio on & the switch on rear defroster AM/FM channels go fuzzy.
Im sure the antenna is in the back window however how would i know that ? (tinted back window would probably void that) Seriously how would i know the back window is an antenna.......................................
That's the XM antenna.
To replace the heated seat light bulb is EASY!
1. Remove silver trim garnishes on both sides.
2. Remove a few screws on the center console.
3. Push back center console.
4. Now you have access to replace the bulbs.
the How to's show soldering and such.. i have no time or patience for that. Do you guys think my warranty would cover that, has anyone actually gone to dealer?
Also my driver mirror is brown inside for some reason anyone know what thats about?
The brown mirror I have read is from the heat being on while there is no ice on the glass.
Only way to fix it is to buy replacement glass or use multivex mirrors over it.
I think my mirrors were the worst I've ever come across on this site.
Can't believe I drove with them for a year !
Mine took up almost half the damn mirror LOL
Came this way when I bought the car.
I've never turned on the heated mirrors before.
Don't plan to especially with my new ones.
I knew the bulb wasn't bad, because if you tapped the switch, the light would come on... (Mine the orange bulb intermittantly worked) So I pulled the schematic from the service manual, and showed the service department, and showed them that the schematic shows the switch was a double position double throw switch, (basically it was two switches in one. One for the heater, and one for the bulb),and that one of the poles controlled the relay for the heated seat, and the other pole was for the bulb. Since tapping on the switch makes the light come on, the switch for the bulb was intermitant/faulty. I even pointed out the warranty documentation that showed that switches were covered, and that their rationale that the switch was ok, because the heaters still worked was faulty, becuase the schematic shows the switch was double pole, meaning that the part of the switch controlling the heater was ok, but the part controlling the light was faulty. The service department still refused to fix it under warranty.
+1 and plug n play LED's are now available. It's a pretty simple fix. The dealer maybe hesitant to fix this as others have stated plus I'd rather DIY than take it to them to potentially damage something else.
I would change the bulb myself. I don't trust the dealer to do anything. They will most likely damage parts and break clips without telling you. Then you will wonder why you have new rattles.
As for the brown mirror, I would not just blame it on being heated. The 2nd gen cl/tl has heated mirrors and never seen this happen on older acuras. It is very common on audis tho. I would think it is just a quality issue where they are cutting corners now like the dash that cracks in the 3rd gen. You won't find any 2nd gen or older acuras with cracking dashes either.
3G TL/2G MDX Owner
my driver's side seat heater switch light was fixed by my dealer free of charge (i was there getting a few other things done, oil change etc). i just asked them to take a look at it, they swapped the bulb. mine was intermittent when the light would turn on. the seat heater worked fine.
i think i was just outside my warranty period too (like 9 mos out of my original b to b). there are still some decent dealers out there that will take care of you. granted i have service history with them which usually helps.
OP- not sure about the fuzzy FM/AM stations with the rear defroster turned on. do you have tint in your car? from what i gather, in your post is that you don't have tint?? i don't listen to the radio in my car...only XM or CDs.
i think i was just outside my warranty period too (like 9 mos out of my original b to b). there are still some decent dealers out there that will take care of you. granted i have service history with them which usually helps.OP- not sure about the fuzzy FM/AM stations with the rear defroster turned on. do you have tint in your car? from what i gather, in your post is that you don't have tint?? i don't listen to the radio in my car...only XM or CDs.
My experience with interior lighting is that it is not covered under warranties unless it is part of the instrument lighting, as that may be a safety issue. The "D" indicator went out in my wife's CR-V (on the dash) and Honda originally was not going to cover it. I showed them that instrumentation lighting was covered and they did the work without further hassle (can only imagine what it took/cost to do that little light, but it was annoying).
That being said, I think it is up to the dealer and your relationship with them. Some dealers may assist, but I don't think it's an issue that would be covered under an extended warranty. Good luck!
^^This.
Most lighting is considered a "wear" item and is not covered under warranty.
With that said, having a good relationship with a dealer you trust can take you a long way. If you're new to Acura, or your particular dealer, a goodwill purchase of a couple pizzas at lunch time will do a lot to establish that new relationship on a positive note.
thanks for all the feedback, Well i found out DCH Acura In Verona NJ SUCKS. I try dealing with one service guy he quit... New guy i spoke to a few months ago also is no where to be found. I got an 80 year old man helping me claiming they don't take Wheelz Warrenty blah blah then says oh wait we do never mind... I almost flipped his desk over. Then starts telling me its 177 to look over everything and they deff won't cover it I go then why would i waste my time here. walked out got some food and now I'm home on AZ.
OK So changing the light bulb for that switch is easy? no soldering? Anyone know the bulb size or where i can get one? also A how to on how to get the switch out?
I was thinking getting a new switch but if its easier to just change a plug and play bulb I'm totally down to do that. all feedback is appreciate.
PS that mirror is not the worse i have seen, I saw a TL wit maybe an inch of mirror left to it i took a pic I'm going to look around for it. this car disappoints me sometimes =[
Just Called a different Acura and they have the part, nicer person answering the phone, I want to range dealerships I'm over the one i go to the rudeness and not knowing what there talking about is really getting to me.
Mine still work fine
Oh and btw, a few years ago when my car was still under warranty, I noticed that one of the blue LED lights in the top console was burnt out so I took it to the dealer to get it replaced. They said something like they had to replace the whole circuit board thing under there, but to summarize, they DID replace it free of charge. I was fine with that, I just had to re-program my homelink.
There was a series of videos for removing all of these pieces by LoveMyTLS (I think).
I have the same bulb out on my drivers side.. it bugs me to see only one of my heater switches lit up. I think Ill do it when i start my a/v install in the armrest..please let us know if its easy
Huge Success!
So basically what I did was take a butter like (like stated in other threads) and wrapped a cloth around it and started from arm rest and worked my way up lightly prying up.
When I got as far as Volume Knob and Right side (selector knob) I STOPPED
...Heard cracking-noise
Moved both seats back as far as they go and opened center console. and removed the rubber bottom/and 2 screws under it. put them in cup holder
From there I was able to see maybe 8-10 screws, this was without really moving the Trim pieces as they were held on by a thread
Put all the screws aside and was able to (without ANY real force) slide the center console back
At this point i was able to see all crumbs, stains, sticky shit etc below(great time to clean, of course i didn't because i was all stressed out about breaking something
Now I see Both heated seat switches and try taking them out however they feel held in by something, took a short phillips head screw driver and removed 2 gold screws, LOST 1!
but grabbed hold of the other, and switch came right out again with no force.
Clearly you can see the wiring harness attached and was about to remove that again NO force necessary and VIOLA i had the switch in my hand..
CAREFULLY pulled off the white sticker and set that aside and had full access to my screw-looking blue bulb.
lightly turned it counter clockwise, and put the new one in.
This whole process took less then 30 minutes and probably would have went faster if I wasn't a nervous wreck.
Got the Part at Open Road Acura in Wayne NJ (35852-SEP-A02) for $6.42 with tax..
Not bad.
Put everything back even the switch with the missing screw that i hopefully find someday. Putting everything back together was less then 5 minutes.
Next task is cleaning under there, going to search for a thread in the Garage on removing driver seat.
Thanks again for all support everyone
PS on a scale from 1-10, this job was about a 2 For a noob like my self.
)Now I see Both heated seat switches and try taking them out however they feel held in by something, took a short phillips head screw driver and removed 2 gold screws, LOST 1!
but grabbed hold of the other, and switch came right out again with no force. Clearly you can see the wiring harness attached and was about to remove that again NO force necessary and VIOLA i had the switch in my hand..
Not bad.
CONGRATULATIONS ISOSUNRISE6!! Feels great to get something done like that doesn't it! Glad you were able to get it done.
Thanks for the follow up with your experience and the details. I am sure that they will come in handy for anyone that has to remove those trim pieces and especially for those that have to do this exact job.
I had one burnt out probably 4 years ago and I replaced it. (It is not hard, but a bit of a pain.) Later the other one went out and I never got around to fixing it. It always drove me crazy seeing only one lit up, but recently the other one went out and now I'm happy with both of them being out!
ok I don't mean to sound like a newb/idiot.... but what blue lights are we talking about here? my heated seat switch only lights up orange..? I bought the car used and thats how its been since I owned it.
3G TL/2G MDX Owner
OP's car with the overhead blue LED...probably aftermarket and installed by PO which makes it a little brighter. stock blue LED for overhead is there but you really have to look for it. its meant to be an accent not usable light.
