Are the stock HID bulbs 35w or 55w
I need to do a replacement and I was just curious if they were 35w or 55w.
Additionally if they were 35w bulbs can the OEM ballast handle 55w bulbs or does it not have the output for that?
dc5chris209 (12-29-2011)
Land of 10,000 lakes
Our ballasts are 35w with the stock HID set up. If you're wanting to run a 50w set up, you're going to have to upgrade the ballasts. I believe you can run any bulb with the 35w or 50w ballsts it's just going to shorten the lifespan of the bulb if you're using something other than what's dedicated for a 50w ballast. You wont need a new wiring harness, just have to be carefuly with the extra heat that the 50w ballasts throw out, you run the risk of melting the projector bowls. I've talked to Matt (Owner of The Retrofit Source) about this issue, he said our projectors are big enough where you shouldn't run into any melting issues.
Ballasts:
http://www.theretrofitsource.com/product_info.php?products_id=163
If you go this route, you'll have to do some wiring from the stock wiring harness to be able to connect the ballasts.
Bulbs:
http://www.theretrofitsource.com/product_info.php?products_id=240
Ballasts:
Bulbs:
just get OEM philip bulbs. Your ballast is 35w. Don't run 55w there just too much light its. It makes your eyes get tired during long drives. I have a set of fx-r with 55w and philips 85122+ bulbs and I am swapping the ballast back to OEM musashita 35w.
The Retrofit Source's ballasts and bulbs look nice but has anyone used them? One of my ballasts went out on me so it gives me a excuse to upgrade lol.
LogicWavelength
3G TL Photograph Gallery
33
11-01-2015 09:38 AM
AmplifiedDetails
09-24-2015 02:55 PM
