Steps to set parking brake?
Old Nov 14, 2008 | 03:15 PM
Rounder's Avatar
2008 Acura TL
This may be the dumbest question ever asked on here, but here goes:
What are the proper steps to set the parking brake in your car (automatic transmission)?
1- Move car into desired parking spot on hill.
2- While in drive, with foot on brake, set parking brake.
3- Shift car into park.
4- Release foot off brake.
5- Turn off ignition.
And is it true you shouldn't set the parking brake in really cold weather (0 degrees F or colder?).
Old Nov 14, 2008 | 03:19 PM
timmahh's Avatar
it's me, Alan Rickman.
I remember seeing something about this before.. I believe you are correct; you want the brakes to hold the weight of the car, not the transmission.
Not sure about the cold weather thing.. o_O
Old Nov 14, 2008 | 03:28 PM
anarchy[sear]'s Avatar
KICKED IN THE BALLS
Ummmmm I choose number 3. Sometimes the ebrake will freeze when its really cold but I only had that happen once or twice on a crappy vdub.
Old Nov 14, 2008 | 03:43 PM
JERU's Avatar
What exactly freezes, its all springs and cables?
Old Nov 14, 2008 | 03:50 PM
CarrieLynn's Avatar
that is the way I have always done it.
My ebrake in my accord freezes up sometimes but the car does not get driven too much.
Old Nov 14, 2008 | 04:11 PM
mglax13's Avatar
New shoes on my
I get to the parking spot and hold down the brake pedal, stick the car into neutral, then apply the parking brake, then remove my foot off the brake pedal, let the parking brake take the weight of the car, then re-apply the brake pedal and put it into park.
Old Nov 14, 2008 | 05:02 PM
trojanman10984's Avatar
boost 3G
that is exactly how to do it! they talked about it when i had to take a defensive driving class HAHA but yea thats how to do it
Old Nov 14, 2008 | 05:06 PM
Sal's Type S's Avatar
Same here...
Old Nov 14, 2008 | 05:14 PM
ray-ban's Avatar
I'm lost..
This is right out of the owners manual
Old Nov 14, 2008 | 06:20 PM
csmeance's Avatar
Best way to do it:
1. Find spot and pull in
2. Shift to neutral
3. Pull up parking brake
4. Let off foot brake, the car will move slightly back
5. Press brake
6. Shift to park.
this way the weight of the car is already resting on the parking brake rather than the transmission
Old Jan 10, 2009 | 09:59 PM
VQPower37's Avatar
this is how i did it too, and i thought i was just being super careful, i dint know it was an actual procedure that was in the manual
Old Jan 10, 2009 | 10:16 PM
mglax13's Avatar
New shoes on my
I didn't know it was in the manual either...lol
I just figured it's common sense. You want the parking brake holding the weight, not the transmision, and this is the only way I can really imagine doing that. Basically, the only reason you have to put the car in park is so the key will come out of the ignition.
Old Jan 10, 2009 | 10:20 PM
Babnik's Avatar
Also don't set the parking brake if you will be parked for a long time, the spring can lose its springiness.
Old Jan 10, 2009 | 11:30 PM
Mr. TTL's Avatar
Old Jan 11, 2009 | 12:12 AM
chairguru22's Avatar
Unregistered User
Originally Posted by csmeance
Best way to do it:
2. Shift to neutral
5. Press brake
6. Shift to park.
This is what I do also.
I have heard that if you never use the parking brake at all, it will freeze/rust into that position and will break it or make it really hard to use. I'm sure cold weather has a similar affect but I guess it would have to be really really cold.
Old Jan 11, 2009 | 09:24 AM
T Ho's Avatar
Best way to do it:
2. Shift to neutral
5. Press brake
6. Shift to park.
That's the way I do it in the auto car.
Old Jan 11, 2009 | 11:38 AM
MichaelBenz's Avatar
CTS-V Import Slayer
I just rip it up from time to time when the car slides in the driveway. Other than that...I never use it. Its an automatic for gods sake...no need. But I dont live in an area with big hills either that we have to park on.
Old Jan 11, 2009 | 08:34 PM
GeezerB's Avatar
I use my E brake for drifting. On my 3rd set of tires in 3 months.
Old Jan 11, 2009 | 08:37 PM
ABP_04TL's Avatar
6-SPEED LOVER
i put mines in Reverse or 1st, then apply the E-Brake then let go
6Spd!! lol
Old Jan 11, 2009 | 09:03 PM
wall e's Avatar
TL=True Love
IMO, i think the dumbest question ever asked here was "how do you accelerate?"
Old Jan 11, 2009 | 10:33 PM
ABP_04TL's Avatar
6-SPEED LOVER
dats tru i agree
Old Jan 11, 2009 | 11:28 PM
Rob RiL's Avatar
Unregistered User
By buying a TL.
rockyboy
Aug 4, 2024 10:35 AM
iesu3423
Sep 29, 2015 08:04 AM
jliu6789
Sep 8, 2015 08:02 PM
braveheart
Sep 7, 2015 08:12 AM
Stu2414
4G TL Problems & Fixes
Aug 30, 2015 07:30 PM
