AcuraZine - Acura Enthusiast Community (https://acurazine.com/forums/)
-   3G TL (2004-2008) (https://acurazine.com/forums/3g-tl-2004-2008-93/)
-   -   Step by step with pictures for removing rear seat (https://acurazine.com/forums/3g-tl-2004-2008-93/step-step-pictures-removing-rear-seat-736731/)
mike421 Jul 21, 2009 08:35 PM
I was thinking of buying Tein SS coilovers and wanted to know if there is a step by step with pictures on how to remove the rear seat.
01tl4tl Jul 21, 2009 08:50 PM
have you looked in the Garage/DIY section for it?
Just a few bolts on the seat ends and 2 hidden in the middle
iirc the gen3 has a bolt behind the headrest- might allow access to the shock mount bolts just from that
csmeance-southern-other expert-- is that correct?
mike421 Jul 21, 2009 08:53 PM
thanks
pohljm Jul 21, 2009 08:56 PM
dont remove those hidden bolts. just loosen them!
or you will wish you did!
sleepyrx Jun 20, 2011 05:32 PM
Why? You can just screw them in slightly after removing the seat to accomplish the same, and then hook the seat back on. I tried to not remove them, and it took forever.
Noober Jun 20, 2011 05:42 PM
remove them fully, its fine. just use a flashlight to help you after.
Bearcat94 Jun 20, 2011 08:17 PM
It's all in the 3G Garage. Here: https://acurazine.com/forums/3g-tl-2004-2008-93/3g-tl-garage-faq-3g-tl-newbies-553554/
D-091: DIY:Front and rear damper/shock spring replacement
https://acurazine.com/forums/car-parts-sale-361/fm-modulators-group-purchase-173827/ - Service Manual Scans
https://acurazine.com/forums/3g-tl-tires-wheels-suspension-97/diy-ht-spec-coilver-install-dummies-any-other-suspension-3g-garage-d-091-a-816065/ - w/Pics and including Rear Seat Removal
F-070: DIY: How to remove the back seats to put the suspension?
https://acurazine.com/forums/showthread.php?t=107568
wtf8269 Jun 20, 2011 09:43 PM
^And if that wasn't enough...
https://acurazine.com/forums/showthread.php?t=816065
Mafyoso Jun 21, 2011 11:21 AM
FYI Be careful with the Clips Under the Bottom Rear seat which are located at the Front of the bottom rear seat. I Sorta Broke mines since I didn't know how the hell they came apart. I just pulled and they broke apart so be gentle and figure out how they come apart before pulling then out. I need to go to Acura and order two more sometime soon.
csmeance Jun 21, 2011 11:33 AM
the trick to NOT breaking them is PUSH DOWN ON THE SEAT while PULLING THE CLIPS OUT!
Also another trick is NOT to take out the screws behind the headrests but to simply loosen them a few turns. The seat is designed to slide onto them to make putting it on easier!
rockstar143 Jun 21, 2011 11:36 AM
^^^that is teh absolute truth.
You can get away with putting the seat back in without any of the center bolts holding down the butt portion. Makes it much easier to access later. Did an install this weekend and was able to even get to the 2 top nuts without removing the rear deck. It was tight, but manageable.
© 2026 MH Sub I, LLC dba Internet Brands
