Steering Wheel Button's
Old Aug 19, 2005 | 09:23 AM
  #41
rbf351's Avatar
Registered User
Originally Posted by xristos
The link provided needs a log-in & password.
yes it does, but its not something i can give it. it was give to me about 5 years ago, and only the parts department of Honda/Acura has access to this
Old Aug 19, 2005 | 11:54 AM
  #42
xristos's Avatar
.:HALCÓN DE LA NOCHE:.
Well I decided to take a closer look at the audio switch remote & HFL switch on the steering wheel. I tried removing the assembly holding the volume, channel & mode buttons first. The two screws behind the steering wheel where easy to remove , but the whole peice wouldn't come off. The horn cover and airbag needed to be removed. I stopped there and didn't wan't to mess with the airbag. I did see two bulbs on the back. One bulb for the "mode" button & one for the "volume" and "channel" button's.
Next, I removed the HFL switch assembly held by two screws. I needed to remove the plastic cover hiding the screw's. I was very careful not to break off any tabs. Behind the assembly you can see two bulbs. One for the top row for the "navi voice" & "answer call" button's. The other bulb is for the bottom row "cancel voice" & "hangup call" button's.
I recommend you don't try to change the bulbs yourself because you might break or scratch the parts or surrounding areas, unless you are no longer under warranty.
So inconclusion, ALL the buttons on the steering wheel should illuminate when you turn on your parking or headlights. The one's circled in red in the above picture DO NOT light up.
Old Aug 19, 2005 | 12:56 PM
  #43
cM3go's Avatar
just use www.acuraparts247.com
Old Aug 19, 2005 | 01:35 PM
  #44
rbf351's Avatar
Registered User
Originally Posted by cTLgo
thats a good site but nothing is as good as partspeis.com
here are some scren shots from there
Old Sep 23, 2005 | 01:45 PM
  #45
Have you got a username/password we could use?
Old Sep 23, 2005 | 01:53 PM
  #46
rbf351's Avatar
Registered User
i do have one, but i can not give it out. it was given to me 5 years ago, and i was told not to share it. sorry
rockyboy
Aug 4, 2024 10:35 AM
Feb 25, 2020 09:57 AM
PortlandRL
Sep 14, 2015 12:01 PM
SpraykwoN
ILX
Sep 11, 2015 08:45 PM
Charlespsu
Sep 2, 2015 09:54 AM
