Steering feed back
I own a 2005 TL- Auto Non Navi, 37k miles. Here is my question, I have noticed when within a long sweeping turn for example going from one highway to another you know a cloverleaf there is a strange pulsing i feel in the steering wheel. As I hold pressure on the wheel to keep the car turning the amount of pressure required changes. This typically happens around 30-40 mph with increased speeds the problem becomes more pronounced. As the car is in the arc it tends to drift as to then require adjustments to maintain the same line through the corner. With the steering and suspension as tight as they are in these cars I would have expected much more precise steering input/control. Tire pressures were all good and tire wear is also good, It almost feels like the inside tire as a increased rate of ackerman and that it is trying to pull the car more than the other tire. I have spent some time as a race car driver so i might be a little more sensitive to these issues than most. Any feeback would be greatly appreciated.
thanks
Jamie
thanks
Jamie
same prob here
i have this exact same prob. It has been talked about here a lot, i can not remember if anyone came up with an reason as to why this is happening. I have a 04 with 55k and my car has always done this. BTW i have the crappy mxmh4 tires.
peace
peace
rockyboy
Aug 4, 2024 10:35 AM
