Squeaky Breaks???
Old Oct 20, 2005 | 11:28 AM
inan0therlife's Avatar
Squeaky Breaks???
ANYONE COME ACROSS THIS PROBLEM??? I have put the coating on the breaks already once... only had my 2005 since Jan.... but th breaks squeak right now... would upgrading my rotors solve this problem??? ANY IDEAS???
Old Oct 20, 2005 | 11:32 AM
HEK's Avatar
HEK
Team Nighthawk Mambo King
I have had them squeal every now and then but it goes away once I wash and rinse the wheels, ..I have the Brembo front brakes with the 6M so maybe I don't use the brakes as much as those with the automatic transmissions..
Old Oct 20, 2005 | 11:35 AM
i know it sounds funny but ive been down shifting more with the auto... using the triptronic to dwnshift....
Old Oct 20, 2005 | 12:28 PM
AcidHorse's Avatar
What is that coating on the brakes are you talking about?
Old Oct 20, 2005 | 05:05 PM
millerrh's Avatar
Mine squeal too. Looks like there was a TSB for this for the 2004's. Maybe the problem came back. I'm thinking about taking mine in.
https://acurazine.com/forums/showpos...2&postcount=11
Old Oct 20, 2005 | 05:24 PM
Brettg's Avatar
I have always found high temp disk brake grease to work much better than
the sticky stuff.
I have tried the sticky stuff, and it just made a mess of everything, and I still
had brake noise.
You would need to clean the sticky stuff off the pads and the pistons, then try
the grease.
Disks have nothing to do with noise, pads do, how they fit, their compsition,
and how they slide on the caliper contact points.
I grease the contact points also.
Its also important to bed the pads in correctly, you do moderate stops
without letting things overheat, usualy by slowing down hard from 60 to say 40
mph a bunch of times when new pads are fit.
otherwise glaze builds up and causes noise.
Cant say I always bed the new pads in, but I still get no noise...
The original setup on our 2005 6mt is quiet and smooth so far, i have
done nothing yet, not even had the wheels off...
Brett
Old Oct 20, 2005 | 08:19 PM
cjhurtado2's Avatar
same situation on my 05 TL last month. Right front brakes. They replaced the brake pads for free for both front brake pads. Original pads are not good according to Service Manager. Best bet is to bring to the dealer. Its under warranty.
Old Oct 20, 2005 | 09:29 PM
J Dubya's Avatar
Home Of The Gemini Method
At about what milage does this occur? I have had my 05 MT since mid-Aug and now have 3200 on the odo.
Old Oct 20, 2005 | 09:37 PM
cM3go's Avatar
discussed many times
lanechanger
Oct 13, 2015 10:56 AM
peti1212
ILX
Sep 22, 2015 11:11 AM
iRaw
ILX Photograph Gallery
Sep 10, 2015 12:29 AM
