Spots on Tach and Speedo Glass
Old Aug 4, 2006 | 07:14 PM
Cecilt's Avatar
Was cleaning the TL tonight and applied some glass cleaner to a rag to wipe off the 3 pods. The tach and speedo showed immediate spots that will not come off. The gas pod is fine. I have no idea what could be causing this but it is very noticeabl eand annoying. Almost like they are water spots but they do not come out. Anyone else experience this?
Old Aug 4, 2006 | 08:47 PM
yes it seems to be 'out-gasing' of the plastic and the 2 line I believe on the tach has 'notches in it on the 2004's
Old Aug 4, 2006 | 08:51 PM
triggle's Avatar
'04 6mt Pearl
A few guys had this problem in the past. I did not see a solution and since I have the same problem I look forward to hearing from someone repaired this. I think the spots are on the inside of the lenses.
https://acurazine.com/forums/showthr...ots+instrument
Old Aug 5, 2006 | 12:25 AM
Cecilt's Avatar
I have a scheduled appt on Tuesday night for an oil change at the dealer i bought the TL from. I also think these spots are on the inside of the glass. Will they replace the glass? I can't beleive this is a stockable item. I'll certainly ask. Weird why this happened as soon as I applied my cloth with glass cleaner sprayed onto the cloth to the glass pod. BTW, I use the GM glass cleaner that comes in a can which is the best glass cleaner I have ever used on a car or my house windows. Windex suks in comparison. Guess GM does make some good stuff like this and the GM Synchrocmesh Friction Modified fluid for the tranny. BTW , mine is an '06.
Old Aug 5, 2006 | 02:06 PM
ubnpast's Avatar
you can always take it apart, and use TurtleWax's polishing compound and rub them out
Old Aug 5, 2006 | 04:13 PM
Cecilt's Avatar
If it's on the inside, which I almost certain it is I will let the dealer handle this under warranty.
ITSJESTER
17
Dec 6, 2018 02:29 AM
blacktsxwagon
Oct 27, 2015 10:12 PM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
