A-Spec Suspension Stiffer Than Type-S?
Old Feb 21, 2008 | 08:56 PM
TMLInfinity's Avatar
Hi,
I have an 06 TL with the A-Spec suspension on it (stock rims / tires).
A friend just got an 08 TL-S and it seems his suspension is stiff but a little softer on bumps...... he also has stock TL-S rims / tires.
I always thought A-Spec suspension would be less stiff than Type-S but his Type-S seemed less bumpy.
What do all of you think?
Is it possible my A-Spec springs got installed incorrectly? I mean it was installed at an Acura Dealership but just not sure...I guess i'm just shocked cause i heard Type-S was stiffer but it was indeed slightly softer.
Thanks.
Old Feb 21, 2008 | 11:54 PM
csmeance's Avatar
The A-Spec is stiffer than the Type-S suspension. This is the order the suspensions go in, softest to firmest:
07+ TL Base
04-06 TL
07+ Type S
ALL ASPEC
Old Feb 22, 2008 | 12:24 AM
JCL622's Avatar
A-spec steering wheel ftw
Aspec suspension is the same one you saw in the magazines for Team Honda Research.
http://www.hondanews.com/search/phot...erhill&s=acura
so in other words, it is a real track tuned suspension.
the TL-S is basically the engine, everything else was "beefed" up slightly to match the new power.
for the MAX benefit straight out of the dealer, you'd have to have TL-S A-spec
Old Feb 22, 2008 | 12:53 AM
Bearcat94's Avatar
AZ Community Team
I don't think that's right.
The suspension was modified with custom H&R coil-overs, a Progress adjustable rear sway bar and adjustable SPC camber ball joints and links.
http://www.hondanews.com/search/release/2399
http://www.hondanews.com/search/release/3081
Old Feb 22, 2008 | 03:23 AM
JCL622's Avatar
hmm maybe you're right. I can't remember whom i heard from that Honda R&D used the same A-spec parts.
LOL i wonder if it was the dealer... @_@
Old Feb 22, 2008 | 05:58 AM
ggesq's Avatar
https://acurazine.com/forums/showthr...uspension+type
Old Feb 22, 2008 | 06:37 AM
S PAW 1's Avatar
Having owned both, the A-Spec is stiffer, but not as refined. The A-spec would literally get airborn on a curvy road with uneven road surfaces.
The Type-S seems more planted and secure IMO, even at higher speeds.
Old Feb 22, 2008 | 07:41 AM
stillhere153's Avatar
94 DC4 RS LSV/Turbo
a-spec suspension ftl
MrHeeltoe
20
Feb 23, 2023 01:54 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
adreano17
Sep 29, 2015 08:48 AM
MrHeeltoe
Sep 28, 2015 05:43 PM
4drviper
Sep 23, 2015 07:42 PM
