Spark Plug Questions
Old Nov 7, 2008 | 06:24 AM
BMT62688's Avatar
So i was told recently that i should only put NGK plugs in my car and about a week ago i put some boschs in the guy told me i should take them out right away so i guess what im askin should i go grab some NGK's and replace them or will the bosch's be fine
Old Nov 7, 2008 | 08:33 AM
GLowrdr's Avatar
Don't feed the...WTF?
Bosches will be fine, but I would maybe change them a little sooner than later (maybe 50-70, instead of 100,xxx)
Kind of like putting lower premium gas in your car. You dont have to syphon everything out cause its going to blow up, but you will get better performance with the good stuff in there.
Not really sure how much of a difference plugs make though, but just to be safe I would consider the NKG the stuff to have
Old Nov 7, 2008 | 09:00 AM
01tl4tl's Avatar
Acura approves 2 brands for a reason- our hi energy ignition and bosch plugs are not a match!!!
Denso cost more and last less mile, so NGK Iridium are what is stock in the car and the best choice replacement at this time.
Yank the bosch now and return them as wrong item
Install NGK
Enjoy
did your buddy say seafoam is bogus too?
Old Nov 7, 2008 | 10:24 AM
jmbnova's Avatar
How may I help you.....?
IS seafoam bogus??
Old Nov 7, 2008 | 12:36 PM
BMT62688's Avatar
no if he said seafoam is bogus i would have slapped him i think the stuff is great
Old Nov 7, 2008 | 06:18 PM
01tl4tl's Avatar
seafoam is only bogus if you are able to totally disregard ALL the instructions here saying slow slow sip sip is the way to get it in the vac port---
and you dump a full can in the intake vac in 5 seconds...the engine stutters-stalls and backfires, dousing you in seafoam,,
but you really have to try hard to do that
But get the bosch plugs out- other members ran them for a few months then reported better running car when put back on the proper japanese plugs for japanese cars!!!
Bosch goes in bmw~ I replaced many hundreds of them over the years
Old Nov 8, 2008 | 12:26 AM
OctoberFestFan's Avatar
I love Beer
I had denso before, it cost me more money and lasted only about 30k. I then put on NGK iridium. I would not put anything else but NGK-i from now on. The NGK is said to be able to last about 40 to 50k.
I would go with NGK-i.
Old Nov 8, 2008 | 07:27 PM
RickyRatchet's Avatar
Yesterday 11:24 AM
jmbnova IS seafoam bogus??
i think it works really well, its the cheapest and easiest way for a quick tune-up...especialy since you're supposed to change the plugs shortly after the seafoam treatment as well as your oil. if you need more info let me know
Old Nov 8, 2008 | 07:46 PM
01tl4tl's Avatar
you need more info!!!
there is NO need to change the plugs after foam unless you have high mileage plugs AND you fail to do the after drive- then you will carbon load the old plugs and need to replace.
Most of us have over 70k when we foam so we go ahead and do the plugs
If you do the oil- then you need to change the oil and filter
Old Nov 8, 2008 | 08:12 PM
i should have been more specific when i said change the oil and mentioned the filter as well. i thought that was common knowledge.
i didn't know about the carbon loading on the plugs without doing the drive afterwards. i agree don't change them if they're not high mileage tho
Old Nov 9, 2008 | 02:50 AM
01tl4tl's Avatar
failure to do the afterdrive will usually result in fouled/loaded plugs, thats just basic science
at 30k I would not worry- at -70k miles I foamed and changed my spark plugs
Old Nov 9, 2008 | 08:19 AM
jmbnova's Avatar
Off topic just a bit but what is the ultimate, finite purpose of doing the seafoam process? What is the ROI?
Old Nov 9, 2008 | 08:51 AM
01tl4tl's Avatar
read the can! or google or wiki or seafoamsales.com
it dissolves carbon-glaze-crud buildup in the carbs/injectors, cleans the intake valves (better fuel distribution to the cylinder), and the piston tops (better combustion on clean surface)
So basically- its tune up in a can--that really works- since 1940!!
In the oil, it dissolves buildup in the oil passages, cleans the piston rings (better seal) and all the tiny ports oil goes thru get a good scrubbing
My oil filter was full of crud after 150 mile drive with seafoam- on a new filter~
Old Nov 9, 2008 | 11:10 AM
devin1tl's Avatar
so when should you add the seafoam, before you change the oil or after? also i am currently running the bosch's as well, is it really that big of a deal, you think im losing hp?
Old Nov 9, 2008 | 06:11 PM
Bike Effects's Avatar
2 TL Owner
I changed the original plugs in my 2001 TL at 110,000. They were NGK's and still looked great. Why do anything else than what is recommended?
Old Nov 9, 2008 | 07:44 PM
01tl4tl's Avatar
bosch are not friendly with our ignition system
Acura allows 2 brands- for a reason- designed to work with the japanese engine designs.
Everyone who has changed back to the correct NGK Iridium plug.. found increased mileage, and it ran like a TL again!!
Plugs may appear fine visually, but the reality of how they work- performance starts downhill about 60-70k miles, and the book says replace at 105 with the timing belt- assuming normal service duty- but look at the book and many drivers are in the severe duty list of car use
Replacing them early will not hurt and should improve mileage- the payback~
Old Nov 9, 2008 | 08:25 PM
jdmsedan2003's Avatar
The bosch is fine.Actually,its one excellent brand of spark plug.That guy is just jealous.Or if he is a mechanic,he just want to make some $$$$
Old Nov 10, 2008 | 11:21 AM
01tl4tl's Avatar
No- its proven on the TL by members of this forum
bosch does not work correctly and will wear out fast!!!!
NGK last longer than the other apporved brand- Dendo- denso also cost more!
Acura put NGK in there for a reason
Every japanese designed car or motorcycle I ever worked on had NGK as stock and replacement plug
Only cars I ever saw Bosch in was BMW's and certain other Euro cars
Oddly enough- my american vehicles have always come with/approved champion or ac.
go figure
But the FACT remains- users here have switched back after a few months of deciding, and found it ran better with NGK Iridium
I still get a laugh at the OP statement, knew to buy ngk so installed bosch.....tff
Old Nov 10, 2008 | 12:35 PM
Legend2TL's Avatar
AZ Community Team
I replaced the OEM NGK's again with NGK's in my wife's Honda Pilot at 105K and the originals looked great also. Amazed on how sharp the center electrode was, only very slight insulator discoloration, the only extremely small deposits were on the outer barrel.
Old Nov 10, 2008 | 12:39 PM
Legend2TL's Avatar
AZ Community Team
I think the issue with the Bosch Platinums is the extremely fine center electrode get erroded quicker than the Iridium electrode of the OEM NGK's. I have used the Bosch Platinum's on older Honda/Acura's with great results but I suspect those car's iginition output is not as hot as modern ignitor/coils.
Since you only have to change the plugs every 100K miles it only makes sense to get the best plugs in there. I've seen the OEM NGK's at 105K miles on a J35 motor and they look great.
Old Nov 10, 2008 | 05:02 PM
01tl4tl's Avatar
Its about the TL having coil on plug ignition- very high intensity
Old Nov 13, 2008 | 04:55 AM
BMT62688's Avatar
Oh and one other thing i was told when i got spark plugs to get a heat grade higher is this a good idea
Old Nov 13, 2008 | 11:09 AM
01tl4tl's Avatar
who are you talking to to get this bogus info ?????? well- stop it!
they are not in tune with the TL needs!!
read the owner book- if you are running long distance hi speed trips only- then a step colder plug will last longer and work better for you
For all other normal operation- stick with what the book/underhood sticker calls for.
This does not apply to heavily modified-turbo-s/c cars of course-
but you guys know what plugs to run!
Old Nov 14, 2008 | 05:38 AM
BMT62688's Avatar
This is why i ask things on here before i do it because im pretty sure you guys know a lil more about this stuff than i do
Old Nov 14, 2008 | 07:07 AM
01tl4tl's Avatar
More than your friends do for sure~
Check the owner book- then here, for any specifics on maitenance
Old Nov 14, 2008 | 07:38 PM
2 TL Owner
Just follow the recommendations. Why would Acura recommend the WRONG plug? Sheesh!
Old Nov 15, 2008 | 12:40 AM
hata_61's Avatar
at the shop i work at, every car we've put bosch in, they always come back with a missfire. ngk platinum is the cheapest we ever put in. PLEASE put the NGK's back in!
Old Nov 15, 2008 | 03:25 AM
devin1tl's Avatar
i was running boschs for about 3 months and my car felt like it wasnt running smooth from 3 to 5k rpm, i switched back to the ngk's and it runs smooth and pulls hard again.
Old Nov 15, 2008 | 06:10 AM
01tl4tl's Avatar
there we have it!!! use the correct plugs,
and get smarter friends or ignore the current ones!
btw- the only plug heat change you would do is colder, for long hi speed trips
The Machine
Sep 24, 2018 08:27 PM
pstomps
Feb 20, 2017 03:29 AM
Laoch
1G RL (1996-2004)
Oct 2, 2015 03:27 PM
datadr
Sep 12, 2015 09:12 PM
NSolace
Sep 3, 2015 08:14 PM
