Spare key...
live fast or die slow
Spare key...
So I would like to purchase a spare key but acura wants to charge 60 for the key and like 105 for programming any ideas on a diff way? I tried Walmart but they only go up to 03
KCCO
Well, it looks like eBay has them for about $30 +. Getting it cut won't be a problem, but you will still have to get it programmed for your immobilizer. Many locksmiths don't have that equipment because it can be expensive, but you might get lucky. FYI, they won't be cheap either, because they would have to pay for the expensive equipment that allows them to do it.
$105 seems like a lot, but I've heard of much worse.
Save yourself a headache and go to the dealer, when i bought my car it had only 1 key and i ended up spending almost $300 at the dealer for a new key and key fob programmed but it was extremely important to have that second key for me so i didnt mind coughing up that amount.
Stay Out Of the Left Lane
Received 1,241 Likes
I have an independent guy looking for $129 to do a key for our daughter's Accord.
When I bought my car it only came with one key from the previous owner. I just didn't want the possibility to be left outside and keys locked inside.
I went to Lowes, got a "dumb key" cut for $2.00 it opens the car, it doesn't have any chip on it so won't start it. I also bought a remote transmitter for driver 1 from ebay ~$10 and then programmed it with instructions found here on Acurazine.
If you want a key that starts your car and has a cloned chip from your original... the cheapest option I found was ACE's hardware store for $70. I also called Acura dealers around Houston but those were around the prices you are listing, maybe even more expensive. It depends on what you want and need.
I got 2 transponder keys from Rachel autosport for, I believe $9 each. I got two and the locksmith couldn't get the key properly cut on one of them. I emailed Rachel and she sent me 4 more keys. So I had the locksmith program those and cut also. I am never without a spare key now! Oh I almost forgot-Rachel is on eBay. I will look on eBay and try to link it here.
Ok, the person I bought it from doesn't carry it anymore. I found this instead http://www.ebay.com/itm/2-pcs-New-Honda-Transponder-Key-Blank-Ignition-Chip-46-Free-Shipping-w-Tracking-/221205031755?pt=Motors_Car_Truck_Parts_Accessories&fits=Make%3AAcura%7CModel%3ATL&hash=item3380d8eb4b&vxp=mtr. $10.50 each is the breakdown. Cutting the keys is the worst part of it, sometimes it just is off ever so slightly. Programming the key doesn't matter if it's 1 key or 100. If the locksmith has the program, it really is a 5 minute procedure.
i didnt think of ace hardware i wouldnt mind shelling out 70 bucks
the main reason for this key is not to be used as a spare but as a key in the car for autostart
I found this site, anyone ever used this? Was going to order a spare key and fab myself here soon.
https://ikeyless.com/vehicles/Acura/TL/2006/
I have a friend who had a couple "dumb" keys cut, then he just taped the "smart" key under the plastic around the steering column so the chip from the key is near the ignition and the "dumb" keys work to start the car. Maybe not a smart idea in a high crime area, not really sure how much that would help out a would be thief...
That doesn't make since tho if he had the good key why use dumb keys
Ok so from the little research I have done this is anybody's best option
Avoid Internet sites since there not certain u might be stuck with a bill and a dead key I usually shop eBay but ima avoid it this time
Second buy a key from acura here in Austin tx there selling for 63 bucks the dealer near my house will program it for extra 63
I called ace hardware since someone mentioned it here they actually do it for 70 but I want an actual acura key so I'm buy it from dealer and the guy at ace told me he would program it for free too bad they close at 6 and I'm working
Engineer in Training
Tell your installer to use a different bypass. It'll be cheaper and safer in the long run. Look into modules made by iDataLink (FlashLogic, OmegaLink, ADS), or Fortin. They clone the keye using data instead of another key.
Also...for $36+shipping here if you can wait but personally I'd run to the store and take advantage of the free programming service. http://www.ebay.com/itm/ACURA-OEM-FACTORY-BLANK-IMMOBILIZER-KEY-2004-2006-TL-2004-2008-TSX-/190857617187?pt=Motors_Car_Truck_Parts_Accessories&fits=Make%3AAcura&hash=item2c70001f23&vxp=mtr
I usually trust eBay but every key person I found had neg feedback like didnt work or never sent or never responded also there some cheaper for like 10 on eBay but like I said I didn't trust them, yea the guy was like I can't charge u because I can't guarantee u that it will work all I can do is put the key in the computer and it will tell me if I can't or can't so I was like sweet!! Ill do it that way Cept I didn't get off work till 6 so I told him I would go by tomorrow
I need to get everybody onboard with Honda HDS.
$100 for programming is absurd. It takes a few mins to program the key. Porsche in Houston charges $60 for key programming and their labor cost is $140/hr. Honda labor rate is anywhere from $75 to $110 around Houston.
i had experience. cheapest way would be buy the transponder key on ebay ( i got two for $16). then bring the keys to the dealer and my dealer charged me $56 dollars to cut and program both keys.
or go to home depot to cut yourself a spare key for $2. it will lock/unlock your car in case of emergency ( lock your key and remote in the trunk, believe it or not i have done it before). it just can't turn your car on.
hope this help
hope this help
That's how business works, unfortunately.
