Spacers with no extended studs fml
someone please help me with the install of the front 15mm spacer......i bought these akata spacers with no studs attached. i dont wanna return the front ones and use two different companies. i have the 20mm for the rear that come with studs. i jus need the size of the studs i would need with the 15mm for the front. wheel shops charge to much to do the work. i cant find diy anywhere.....thanks
I agree.
I told you originally to ask the seller whether or not they had type 2's in stock for 15MM because I knew it exists. Why ask if you're not going to listen to the answer?
If you're hellbent on not returning, then take your stock lug (i'm sure you could google length) and add 5 or 10MM to it to make sure the stud would grab.
theres nothing wrong with having two different brands of spacers. as long as the fronts are the same and the rears are the same, then you are fine. just return the 15mm with no studs and reorder.
plus you posted 2 NEW threads already....
hope that helped
