Small crack on front bumper... Can it be fixed?
Old Nov 16, 2012 | 01:31 PM
navarretg's Avatar
2004 Acura TL
I hit a raccoon last night and this happened. Can it be fixed with out replacing the bumper? I bought the front aspec kit for the car yesterday and I know it will be covered but I don't want the crack to worsen.
Old Nov 16, 2012 | 01:49 PM
SharksBreath's Avatar
BANNED
jb weld that crack up, let is set and harden. throw on aspec lip. done deal.
Old Nov 16, 2012 | 02:26 PM
Wacker's Avatar
:what:
There are several ways to repair it. A quick way to keep it from spreading is to drill a small hole at each end of the crack. You can then grind the crack out and use a repair epoxy that stays flexible to fill the areas you ground out. I usually add fiberglass mat to the epoxy on the back side of the repair area to reinforce it. Then you sand, prime, and paint...
Old Nov 17, 2012 | 02:20 AM
mzilvar's Avatar
^^ +1 on drilling holes in the ends of the crack to prevent it from cracking further.
Also 3M makes a urethane type of epoxy for repairs to bumpers
There's a video of the kit and process, to be honest that whole kit is fairly expensive, the gun that is used to mix the epoxy 1:1 is sold separately I'm sure.
They also make an epoxy kit for flexible bumpers that is a lot less for like $10, and I think NAPA has something similar.
Old Nov 17, 2012 | 06:37 AM
Wacker's Avatar
:what:
You can find the stuff at any auto paint jobber (body shop supplier). I use one made by Evercoat that fits a regular caulk gun. It's under $50. They have a quick cure and a slow cure formula depending on how fast you want it to set up.
http://www.evercoat.com/productcategory.aspx?cat=6
Old Nov 17, 2012 | 10:38 AM
navarretg's Avatar
2004 Acura TL
Thanks for the replies! I think I'm going to drill the holes today and search for the JB weld. My aspec lip is coming on Tuesday so I will hopefully have it installed soon!
HairyMonkey019
Apr 22, 2016 10:50 PM
JnC
Sep 11, 2015 06:06 AM
08 NBP TL
Sep 8, 2015 08:49 PM
ptbarnett
3G RLX (2013+)
Aug 30, 2015 12:39 PM
