Shut Off The Auto A/c ?
Miss my 89 Legend
Does anyone know how to shut off the A/C auto on feature when you turn the fan on?? I can't figure out how to just turn the fan on w/o the A/C going on. It is really annoying. And according to the quick start guide "AUTO is displayed when the system is in fully automatic mode etc...." Even though it is linked to the remote transmitter every time I turn the fan on the A/C goes on...
Does anyone know how to shut this stupid feature off??
Originally Posted by rhizopod
Why would you ever want to do this? This is the point of automatic climate control.. just set the desired temperature and forget it!
I never drive with my A/C off.
Originally Posted by Brokedoc
I used to live in Houston too....it might sound crazy, but in some parts of the country, they don't need A/C year-round.
Originally Posted by 93SHOcar
I think that the point here is that by leaving the climate control in the auto mode, the air is always being dehumidified regardless of whether it is also being heated or cooled.
When the weather is cold, hot air is usually enough to keep the windows defrosted and you can save gas when you shut off the compressor. I find that I very rarely need to turn on the compressor during NY winters.
![Agree](https://acurazine.com/forums/images/smilies/agree.gif)
CEO, Team Anthracite
Moderator Alumnus
Originally Posted by Lore
Yah, here in the SF Bay Area (I am about 8 miles east of SF) the weather is typically cool enough where I don't need to use the A/C. However, when I'm on the freeway I turn it on because I like the dehumidified condition of the cabin. In those cases I usually set it to 75 or higher so it only comes on every once in a while.
The other thing to consider here is that not using the AC in the winter is one of the major reasons for compressor (and possibly other AC components) failure. I always try to use the AC at least once a week in the winter. Otherwise, you get moisture build-up, seals may be damaged, and the compressor may seize since the oil is not being circulated throughout the system.
When using the front defroster, the AC will be on by default, regardless of whether you turn it on or not. That's typical in most cars since it will work much more efficiently.
Also, if you have any passengers in the car, their breath will tend to cause the windows to fog up. Especially if you have a lot of wind-bag friends. The AC will help with this.
Not a Blowhole
When I have the window open, I set the Recirc to closed to reduce unnecessary filtration as well.
its now 2007 in my TLS and there is still no solution to this?? Why does the AC have to automatically be on by default? I understand if the system is in auto mode, but even in manual, if i shut the system off and then turn it on again, the AC is on. This is really annoying because in manual mode we should have full control of when the AC goes on or off.
Morbid
I hear ya, but since you can talk to your can, and it talks back, you could just pretend your on the Enterprise and push buttons all the time (turning off the a/c ever time you get in) OR say the word 'COMPUTER' and push the talk button so it seems like ur on the Enterprise and tell it to turn of the f*cking a/c.
Other than that, I feel the same way you do about it. But it would be nice to get photon torpedo's on the car.
WDP Director of R & D
Turn the AC off, then just adjust temp, mode and fan speed as desired. It should stay like that indefinitely unless you hit the AC, defrost, or auto button... Is the 07 different or am I missing something here....?
AZ Community Team
Received 7,771 Likes
So, why not just push the AC on/off button on the right side of the console?
https://techinfo.honda.com/rjanisis/...707O00126A.pdf
Owners Manual Page 127 and 128.
Am I missing something?
Acuras Only in
If you set the climate control to Auto, I pretty sure the compressor cycles regardless of temperature. That's why you take the MPG hit if you leave it on auto all the time.
When it's chilly out, I'd be willing to bet that the compressor MPG hit is <1/2mpg.
And, as missmyprelude noted, *NOT* using the AC is one of the biggest causes of compressor failure. I have two cars that have 12+ years on the original compressors and refrigerant charges, and have never been refilled. I'd lay good money that it's due to the fact that they actually get used from time to time.
Even when you take it off auto, it defaults to AC ON after you shut down the system...and then you have to press the AC button again to turn it off. I know you could just leave the AC on all the time but I dont want to do that. I live in Canada and it gets cold and dry here during winter, no need for the AC to be on. I do use the AC every once in while in winter to keep the compressor moving but i dont need it on every minute...and the cycling of the compressor is really short...I guess there is no way to stop this or you guys would have said so already....oh well, it is just a minor annoyance...I still enjoy the car.
Registered Member
Gee, I never have this problem in either my '04 manual or '05 automatic TL. I use the A/C in the summer months when it make sense, and cycle it periodically in the cooler months to "exercise" it a bit. All other time, I am in the manual mode and everything works great. No automatic A/C coming on when I don't want or need it and no default to the AUTO mode. Can't understand how or why this is an issue or problem when its operation is really quite simple to get the desired settings.
![Roll Eyes](https://acurazine.com/forums/images/smilies/rolleyes.gif)
It stays right where I left it when I shut it off
Registered but harmless
Received 1,107 Likes
Originally Posted by u1arunit
On my '05 I just push auto on, select the mode and temp I want, push the ac button to turn the ac off and leave it that way. Once I restart it is exactly the way I left it.
![Nod](https://acurazine.com/forums/images/smilies/nod.gif)
On restarts, the climate control on my TL stays in the mode I selected before turning off the engine. I bounce between "Auto," setting a temp with the A/C off (I love SoCal weather!), and CC "Off"; the TL never defaults to anything other than what I select.
2004 SSM/EB/5AT/Navi/RSB
I am almost always in AUTO mode. The only times I override it are if I want to get a little more pep (A/C off) or if I need to boost the fan speed to clear out some unpleasant air in a hurry.
i know what you mean. even though the "a/c on" isn't in the display you can hear the compressor kick on. you press the a/c button and the display says "a/c off". i think of it as the system wants to keep windows as clear as it can so whether heat or cold the compressor will kick on.
'10 Hyundai Genesis Coupe
Turn everything off, then turn up the fan and it should not have A/C on or the A/C off display or when just keep the temp on high when you turn off your temp control unit.
2017 TLX TECH V6
just push the ac button to turn the ac off. I did this today. I think I will always do this unless I get fogged up windows. Then I will have to use the defrost which will turn the ac back on. But no doubt, your mpg will be better without the ac running constantly.
Biggie_B
02-26-2017 11:14 AM
