Shimmy???
Shimmy???
is anyone getting the shimmy at any specific speed or range?? I am currently getting a shimmy at around 70-75mph. i just had my tires rotated and balanced. i have brand new tires (Falken 512 - 245/45/17) which were mounted and balanced 1000 miles before. i went to costco to see if another balancing would fix the problem but it did not disappear.
would getting an alignment fix it??
thanks in advance!!
thanks in advance!!
thanks in advance!!
thanks in advance!!
I recommend you go to a tire and alignment specialist. Try one with the new Hunter balance system that compensates for tire carcass stiffness and other tire out-of-roundness. Look on Hunter's website for a location near you (many in CT, also Tirerack boosts of having this Hunter system). The Hunter system also runs the tire on a roller in addition to normal spin balancing. Places like Costco, though a good value, do not calibrate their equipment or set the equipment to the most sensitve setting. Balancing equipment must be calibrated regularly or it will not give an accurate read on the first try.
thanks in advance!!
thanks in advance!!
thanks!! could it be the springs?? hope not. if they are the cause then good thing i have it covered under warranty thru the dealership....let me know how your balancing goes...
I notice when braking from highway speeds the car seems to want to pull to the side. Haven't noticed this before in other cars. Does anyone else experience this, any suggestions on what the cause could be?
ccddo
2G CL Transmission Recall Q & A
Mar 7, 2005 07:51 PM
akhbhaat
Oct 2, 2003 05:53 PM
