shift lag?
Old May 30, 2007 | 07:41 AM
lRageATMl's Avatar
9th Gear
shift lag?
I have a 07 tl (reg not type-s). When I switch into the "manual" mode and go for some spirited driving it almost seems that i have to shift very early to avoid hitting the built in rev limiter...
is this a common thing? I'm so used to driving manual cars (powershifting, i.e. shifting w/o letting off the gas at all)... hell even my parents bmw does a better job at shifting (or shifts for you if you get too close to the redline).
Old May 30, 2007 | 08:10 AM
HiTEC's Avatar
I think that's common on most shift-o-automatic cars. I don't think it's a problem unique to the Acura. Remember you still have an automatic transmission no matter what mode it's in.
Old May 30, 2007 | 09:35 AM
Eoanou's Avatar
'10 Hyundai Genesis Coupe
You have to push it up until it shifts, while keeping your foot on the gas. I use it all the time helps me start off on the right gear.
Eoanou's Avatar
But it does take a second so make sure you do it at like 6600 and it'll shift at like 6800.
Old May 30, 2007 | 11:14 AM
Porkipine's Avatar
'07 NBP TL
I heard grounding kit will improve the lag. I got a set and am going to install it hopefully this weekend.
Old May 30, 2007 | 06:09 PM
PeterUbers's Avatar
LOL! A grounding kit helps with shift lag??? um, ok.
Old May 30, 2007 | 09:03 PM
sT04Louis's Avatar
Nikon Neck Beard Krew
Yo let us know how this goes. Ive called several shops about improving the lag in the 5AT and all they can do is scratch their heads.
SidhuSaaB
May 30, 2020 12:40 AM
Jul 16, 2017 07:33 AM
Popee
Dec 20, 2015 12:08 AM
mellsonnj
Sep 24, 2015 04:42 PM
Hines57
Sep 24, 2015 01:58 PM
