Service question.
Old Feb 23, 2011 | 08:39 PM
AcTL-S's Avatar
Service question.
aryte. I have an 04 acura tl with 92k miles on it. the car runs perfect but i am not waiting for any of the service lights too come on. what steps should be done on the car with the amount of mileage it already has. i just purchased the car 2 weeks ago. thank you.
Old Feb 23, 2011 | 08:44 PM
There is a 105k Service which includes Timing belt and water pump replacement.
some other things to consider.
- spark plugs
- brake fluid
- coolant
- ATF or MTF
- check rotors and pads
- check engine air filter and cabin air filter
Bearcat94's Avatar
AZ Community Team
Do you have previous service records?
AT or MT?
You're coming up on a major service interval, usually ~105k, for Timing Belt replacement. Runs at the dealer, say, $900 - $1200.
Old Feb 23, 2011 | 08:56 PM
AcTL-S's Avatar
No i dont im tryna get my hands on that, and its an AT.
Old Feb 24, 2011 | 12:51 AM
ez12a's Avatar
the overexplainer
if you have zero records, i'd start with replacing fluids immediately.
I got my 04 with 52k miles and no real records other than the pre purchase inspection I had done at a shop. Immediately changed out the motor oil, a week later, the brake fluid and the M/T fluid.
I would do it ASAP unless you can procure records.
Old Feb 24, 2011 | 09:18 AM
jda123's Avatar
Dogmatic Dinosaur
Transmission fluid ASAP. Search on the transmission 3rd and 4th gear pressure switches - a well deserved routine maintenance item that you should consider doing sooner than later.
If you cannot find the records, then bleed the brakes. Change out as much power steering fluid as you can every time that you change oil (just use a turkey baster and empty the reservoir).
Old Feb 24, 2011 | 12:31 PM
LoveMyTL-S's Avatar
Perhaps a radiator flush.
Mike734
Dec 10, 2021 01:25 PM
08KBP_VA
Oct 22, 2019 01:55 PM
thegipper
Sep 28, 2015 01:01 PM
jmaxima03
Sep 27, 2015 10:22 AM
mellsonnj
Sep 24, 2015 04:42 PM
