"Service due soon A"
Old 01-10-2008 | 07:40 PM
..Mark..'s Avatar
What does it mean?
What does the service entail?
How much will it run $$$ (car is under warranty if it matters)?
TIA.
Old 01-10-2008 | 07:47 PM
ggesq's Avatar
https://techinfo.honda.com/rjanisis/...404O00194B.pdf
"A"= oil change. If you don't like changing your own, shouldn't be more than $40- tops.
Old 01-10-2008 | 07:48 PM
..Mark..'s Avatar
Thanks. Once i change it how do i reset the light?
Also is there a list here somewhere w/ all the service codes?
Old 01-10-2008 | 08:03 PM
subbuzz's Avatar
07 tl-s in
the manual list's codes, and hold down the reset button for approx 10 seconds on the screen that says what service is needed then you answer yes when it asks you if you want to clear.............
Old 01-10-2008 | 08:06 PM
..Mark..'s Avatar
thanks.
Old 01-10-2008 | 08:15 PM
Bearcat94's Avatar
AZ Community Team
..Mark.. , Here's a link to Owners Manuals in case you don't have one.
https://techinfo.honda.com/rjanisis/...01_OMANUAL.asp
Services for each code are listed in the Maint section.
You can also set up an Acura Owner Link account and Maint Services are listed there as well.
https://www.ahm-ownerlink.com/login.asp?brand=acura
Old 01-10-2008 | 08:19 PM
ggesq's Avatar
https://acurazine.com/forums/ramblings-12/when-you-mods-close-advertising-threads-91245/
https://acurazine.com/forums/audio-video-electronics-navigation-22/subwoofer-help-90084/
Old 01-10-2008 | 08:33 PM
pokin's Avatar
07TL-CBP
Mark,
Note that the service item (A) will also be accompanied by a number, which is another maintenance item. So 'A1' will be oil change + tire rotation. See manual posted by ggesq.
Old 01-11-2008 | 09:48 AM
1995hoo's Avatar
Keep Right Except to Pass
Originally Posted by pokin
Mark,
Not necessarily. Mine has just shown "A" a few times (including the most recent service....which was fine, as I had just gotten new tyres two weeks earlier and thus did not need a rotation regardless of what the thing said).
Old 07-13-2015 | 12:20 PM
mossman77's Avatar
Yes, I know this thread is ancient, but I didn't feel the need to start another. My display is saying "Service Due Soon A" and holding reset for 10 seconds does not get rid of the notice. After holding the reset button for 5 seconds or so, it progresses to the next screen and the "i" indicator is still lit. How does one reset the reminder on a 2008 MDX?
Old 07-13-2015 | 05:46 PM
dezymond's Avatar
Let me google that for you
Old 07-18-2015 | 08:42 PM
MarcoNorthPolo's Avatar
KCCO
I'm assuming the process is the same for a TL and for an MDX, but wouldn't you get more responses if you had posted in the MDX section?
Mike734
12-10-2021 01:25 PM
08KBP_VA
10-22-2019 01:55 PM
thegipper
09-28-2015 01:01 PM
jmaxima03
09-27-2015 10:22 AM
95oRANGEcRUSH
09-25-2015 12:50 PM
Quick Reply: "Service due soon A"
