Which sealer to use after polishing headlight lens?
Old Dec 8, 2014 | 11:44 PM
  #41
Bruce Banner's Avatar
Originally Posted by AckTL05
I've never had a stress issue from lamin-x. i've seen it quite often from clear coatings. Most clear coats are probably done wrong, but a GOOD clear coat will suffice. Problem is that clear still yellows because that factory headlights yellow and they are cleared with UV…Yes its one of the longer lasting, but when its done half the time is half asses by shops no offense to anyone but I spend about an hour preparing the lens before the laminx and use two DA polishers to remove swirls or small sand marks before applying the film.
The sun just simply kills and another problem is most don't fully "sand and clean" before applying the material/clear..which I have seen clear literally "chip" away like a bad paint job.
Its been about a year and a few months and my headlights still look new thanks to laminx. We did my buddies headlights with clear and within a year it started showing signs of aging, ask cazio who he's been through clearing the headlights and even has spider cracks from it and Im getting him a set of laminx'd lens.
Best part about lamin-x is that it repels dirt, grime, helps against pitting and chips plus after years if it needs to be replaced just peel off/polish the headlight and re apply a new sheet. Higher end shops don't clear, they use laminx or 3M.
What are you using as a sealer prior to laminix Ack?
Old Aug 14, 2015 | 09:47 AM
  #42
imj0257's Avatar
Q('.')=O
So I just got my headlights restored and was thinking of putting lamin-x on them. But I'm concerned about possibly getting stress cracks.
Does the 3M clear bra do any better? XPel?
I'm looking for something so I don't have to restore them every year.
Old Aug 14, 2015 | 11:08 AM
  #43
guitarplayer16's Avatar
Check out Opti-Lens
About stress cracks, I think it really depends on certain variables.
Maybe how long you park your car in the sun, how long its on for, how quickly the temp drops at night, etc.
I can take a picture of my friend's headlight that got stress cracks only in the area the "blue batmobile" overlay was.
Old Aug 14, 2015 | 12:13 PM
  #44
imj0257's Avatar
Q('.')=O
Can I use that after I've already put a clear coat protectant on it?
Old Aug 15, 2015 | 01:58 PM
  #45
whitesoxsfan12's Avatar
In not sure if I applied the Turtle Wax wrong but I basically did nothing to my headlights. They may be faded from the inside of the headlight, not sure.
Old Aug 15, 2015 | 03:08 PM
  #46
vietxquangstah's Avatar
You don't fix faded hazy headlights by rubbing turtle wax on them.
You need to wet sand, compund, polish than seal it
Old Aug 15, 2015 | 07:37 PM
  #47
I should have clarified, I used Turtle Wax brand headlight restore kit which has all of those steps. Didn't seem to work for me but maybe my headlights were beyond repair.
Old Aug 15, 2015 | 07:59 PM
  #48
I find its pretty rare to have haze from the inside unless the headlights have been opened up.
wetsanding should take care of it.
Old Aug 15, 2015 | 08:07 PM
  #49
imj0257's Avatar
Q('.')=O
How long did you sand for? Maybe the haze was so built up that you didn't sand them down enough.
Old Aug 16, 2015 | 12:01 PM
  #50
Got a picture of how bad they look? Can you still see through it?
Old Aug 16, 2015 | 11:04 PM
  #51
Steven Bell's Avatar
Just used the Megs system today on one of my headlights-turned out excellent!
Old Aug 17, 2015 | 02:49 AM
  #52
sopmodm14's Avatar
i just got plast-x as a gift ... do i have to sand it down first ? thought it could be used right out of the bottle, just apply and wipe off
how about wipe new headlight lens restorer ?
Old Aug 17, 2015 | 10:19 AM
  #53
polobunny's Avatar
Registered Bunny
Plastx is good for minor scratches and scuffs but it's not going to magically restore very UV yellowed and sand blasted headlights.
Old Aug 17, 2015 | 10:37 AM
  #54
Plast-X is great, its whats included in the Meguiars Headlight Restoration kit.
It can be applied right from the bottle. It's not wipe on and wipe off by any means. You'll need to put in some elbow grease and spend a lot of time on it.
It is much faster with a buffing machine.
Sanding basically gets you better results, as you're removing small pitting and removing the layer of oxidized plastic.
The Plast-X will bring it back to life after you're done wetsanding with a high grit.
Old Aug 17, 2015 | 11:37 AM
  #55
mvp2765's Avatar
I've used plast-X and it does a great job.. I haven't been putting on a UV protectant religiously tho so haze is starting to come back. I may try to clean them again and put some clear laminx film on them.
Old Aug 17, 2015 | 01:07 PM
  #56
sopmodm14's Avatar
thanks for the replies about plast-x
i got it as a gift,,so might as well use it
how about wipe new for headlights ??
hashbrown
Feb 18, 2022 11:20 AM
BIGxRED
Oct 19, 2015 10:47 PM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
Mr.Tea
Oct 2, 2015 10:32 PM
stogie1020
Cameras & Photography
17
Sep 30, 2015 01:34 AM
