Replacing o2 sensor
Replacing o2 sensor
Hey, so I got these faults this morning. (See below). The car appears to be driving fine.
Bank 1 sensor 1 is rear of engine near firewall, top sensor (upstream), correct?
Additionally, why the hell is this sensor so expensive compared to the downstream ones? lol....
If anyone has replaced this sensor with anything other than Denso, I would appreciate any input on other brands... Or, persuade me to buy OEM.
Thanks!
Thanks!
You could test the wiring going to the sensor, but most likely it's dead.
Get different than Denso and you most likely will be doing it twice, so at least use anti-seize so it's easier second time around. If you get Bosh then you will be getting Denso sooner that you think.
Oh and aren't Denso for like ~$100 from rockauto? I usually get them from autozone for ~$150 but never ordered one for TL so maybe they are more expensive.
You probably need to replace all 4 Oxygen sensors at this age. Paul, our star master mechanic here in Nawth Jerzy says to only use the Denso's or NTK's from rockauto. The NTK's are OEM and come with all the plastic anchors like the originals for the routing the wire. Replacing mine at 315K miles made a huge difference in performance!
I also just completed a $20k home repair/improvement so I am penny pinching hardcore right now, it pains me that these sensors are (relatively?) expensive.... hey, if the name of the brand is ULTRA-POWER, it has to be high quality, right?
But seriously. Looks like I'm just going to suck it up and get 4 DENSOs. I am fearful that the sensors on my car are the original ones, now sitting at 230k. But my fuel economy has never dropped below 24mpg, I guess until this CEL.
06AcuraTLBlk
11-26-2015 03:51 PM
