Replacing 06 front bumper with an 07 Type S
My 06 front bumper is damaged, so i am going to replace it with an 07 Type S one.
This should be a direct fit correct?
Should i get stock 07 grill and fog lights, or is there better options?
Do i need to run new wiring to install the fog lights?
Is this all i need to do, to make the swap?
Veni, vidi, vici
Nope, type-s bumper won't fit from what i heard, it's slightly larger then base TL's, the grill is larger I think, but I'm no expert. and yes you will need to run wiring for the fogs.
^WRONG....The 07 Type-S bumper is a direct fit on a 06 TL.
You will however need 07-08 upper and lower grill components including fog lights and wiring.
There are a lot of threads covering this conversion...
Here is one...https://acurazine.com/forums/3g-tl-2004-2008-93/ua6-ua7-bumper-conversion-help-765014/
Thanks,
So far my understanding is that the 07 type s front bumper, will be a direct fit on my 06 base TL.
and that i need to purchase the following:
07 Type S front bumper
Fog housing
fog wiring/bulbs
lower side fog trim/grilles
Center grille parts, V, cross bass W/emblem, backing
Will it be cheaper if i buy it painted at the dealership, Or go to a body shop and have them try and match the paint and do the installation. What's the best way to go? not trying to go cheaper if it there is a chance of a bad outcome...
Fog housing
fog wiring/bulbs
I think that is all the parts you need.
It's going to be cheaper to buy the bumper unpainted and have a shop paint it. They should be able to match the paint without a problem, just give them the paint/color code for your TL. A quality paint job will probably run you $300-$400. Apart from the wiring, installation is very easy, you should be able to do most of it yourself.
handsom-hustla
11-13-2015 05:04 PM
Oakes
Wash & Wax
10-12-2015 11:17 AM
robowarrio
09-01-2015 09:25 PM
