Removing Light Overlays
AZ Community Team
Need to remove the headlight overlays/tint from my headlights. They are the Blue Batmobile overlays.
How do you do it?
Any tips or tricks?
TIA.
How do you do it?
Any tips or tricks?
TIA.
AZ Community Team
Steven, that's what I was thinking, but wanted to get some AZ confirmaiton.
Wonder if anyone has actually done it and if so, how? Any trouble or tricks?
I am clearing, then blacking out the Headlights tomorrow morning. Don't need overlays no more.
heat with a hairdrier to loosen the glue, then once you start peeling up spray soapy water (car wash soap) on the underside to help the rest of it peel off. Then clean up with car-wash soap. try not to use any abrasives otherwise the headlights will yellow faster later on. You can use fine clay lightly as well.
If you have access to one of those little hand-held steam cleaners, that will make the overlays very easy to peel off. Work a corner off, then steadily pull the overlay off while spraying steam on the glued side. I've never had to use this method but I've seen guys peel off window tint with ease doing this.
JP...that's GREAT. Please take some pictures and let me/us know how it goes. Are you doing it by yourself???
AZ Community Team
Will do.
No F'kg way. I'm too chickenshit to put my headlights in the oven then start fooling around with 'em. I enlisted the help of a couple of local experts - TrevorT and WRXTransformed.
^ Make sure you don't put the hairdryer on the headlights for too long.
I did that and I got a bunch of mini-cracks on my headlights.
I had my overlays on for so long, I had to have a lot of heat
Good luck.
.Good luck.
JP...it sounds like you'll have a household full of help tomorrow. I'm sure they'll turn out great! Shoot some pics of you and the guys doing this mod. Then bring everyone to KC and let's do my headlights. I want to take out the amber too and add the Audi style lights to the original headlights.
AZ Community Team
You outta come over to chill-dog's ~mid-day tomorrow. I'm gonna stop by when I'm done with the HL's and help him with his bumper removal and re-install and maybe do my rotors and brake fluid flush while I'm there.
I'll call you (since your PM box is full.
AZ Community Team
Simple. Easier than I expected.
Just like the guys said - a little heat from the hair dryer and some warm/hot soapy water.
Just enough heat to start the film peeling and keep it going. Lubricate as you pull with the warm soapy water.
No problems.
No problems.
mada51589
Jan 9, 2025 04:40 PM
cycdaniel
Dec 17, 2019 10:58 AM
