Removing decklid spoiler
Old Mar 22, 2008 | 11:53 PM
HiHenry.com's Avatar
Hi, I bought a decklid spoiler recently and it is currently held by 3M tapes firmly to the trunk. However, I find I have to adjust it a bit so would like to remove it and retape it. What's the safest way to remove it without damaging the paint?
Thanks!
Old Mar 23, 2008 | 03:38 AM
ballinfizzle89's Avatar
FizzyStatus!
Start from one corner and pull on it using Goo-Gone or Oops. While doing so, try to pick as much 3M tape with the spoiler so that you don't have to go back and scrape it off later.
Old Mar 23, 2008 | 09:13 AM
Jesstzn's Avatar
Just be very careful pulling as that tape sticks good and might lift the clear.
Make sure its warm.
The methode I use is I saw the tape off with fishing line or dental floss. Them use a littl heat and roll the remaining foam off with you fingers .. any glue residue us goo-gone.
Wipe the area with IPA before resetting with new tape.
Old Mar 23, 2008 | 11:34 AM
Will Y.'s Avatar
Registered but harmless
Make sure its warm.
With a hair dryer, right?
Old Mar 23, 2008 | 11:43 AM
Fulani has a TL's Avatar
Yup, A Hair Dryer will work perfect. Thats what ALOT of people use when debadging (I did).
What I did was kind of restrict the air coming in from the back, by holding my palm close to the intake so that there was less air going in and the air coming out was hotter.
Warm section by section. For example, Heat a 3-6 inch section up, then use kite string or fishing line (dental floss shreds TOO easily) then saw through the tape, leave the string/line there heat more, and saw again; keep doing that till your done.
Afterwards go with goo gone to remove the residues.
My recommendation after you get the good gone completed, polish out the area to remove any scratches that were caused and then use IPA to clean the new area and reapply with new 3M tape.
I rebadged the rear A logo, and didnt polish before I stuck the new one on, and CANNOT get the scratches out. GRRRR
Hope this helps, and good luck.
__________________
Kansas City/Missouri Meet!!!
Old Mar 23, 2008 | 11:46 AM
Jesstzn's Avatar
Yeep or very carefully with a heat gun.
Black cars you can set it in the sun for a while.
In reality the hair dryer etc takes forever to get the heat to where the glue is .
It just aids in sawing off the foam portion of the tape.
Old Mar 23, 2008 | 12:44 PM
frenchbiker's Avatar
Thanks!
Use a 3M eraser wheel with a power drill. Much easier and much faster to remove glue than any other method. My buddy has a body shop and he swears by them when he has to remove emblems, pinstripping etc ...... No risk of damaging the paint whatsoever.
Old Mar 23, 2008 | 12:56 PM
hmm ... sems like a lot of work !!! the tape holds the lid so strong so i think i'll not do anything right now ... thanks guys for all the info !!! besides, i live in a condo so the hard for me to heat up the car in the underground garage ...
quanaman
Jan 9, 2023 07:33 PM
Jul 16, 2017 07:33 AM
rhdune16
Sep 28, 2015 11:31 AM
spoiler900
Sep 23, 2015 04:41 PM
