Rear Wing Spoiler
Rear Wing Spoiler
Have any of you ever installed this by yourself?
http://acura.bernardiparts.com/Acura...2-SEP-XXX.aspx
If yes, can you describe the experience/level of difficulty?
Wingless FTW! You might even find someone local who is willing to trade you a winged trunklid for a wingless one, in your same color.
But if you insist, taking apart the liner in the trunk lid is very easy. Then its a matter of lining things up straight and getting the balls to drill through your trunk lid.
I personally would be much more scared of rust developing years later at the drill sites.
Lining it up should be fine. Just be sure before drilling... use a marker to mark the spot and measure three times, then start the hole with a small drill bit as a pilot, then switch to a the correct drill bit once you have a nice pilot hole started.
I did mine myself. Painted the drill holes and used a bit of silicone to prevent leaks/rusting. There's also a template provided to locate the holes.
I bought the tool to change the springs.
In the end, I wish I hadn't done it, but it's not the worst around.
MonkeyTrucker
Oct 9, 2015 07:53 PM
oyayjoe
Sep 12, 2015 04:40 PM
EE4Life
Sep 11, 2015 10:13 PM
